Recommend a Mini-ITX setup.
zuoom
Hijack a bit.
What are those itx with dual LAN in the market now?
devil1158
Then any regular sized chassis will fits you since regular mid tower under $100 is just 4 expansion slots taller. But you want mITX form factor for compactness right?
looking at compactness.
But if regular tower can give better value. I will consider also..
Just wan to squeeze all the $700 dry dry... lol
CyberTron
If you go with normal casing, you might as well go with m-atx or atx motherboard since there is a price premium for itx motherboard.
If compactness if all you want, then you should start with a compact itx casing. If you have no need for future expansion or addition of graphics card, then you should go with some very compact itx casing like those from antec.
nippp0n
CPU & Mobo: i5-3450 & Gigabyte B75M-D3V @ $317
Ram: Free 4GB Ram
ODD: Samsung DVD RW OEM @ $22
HDD: Hitachi Deskstar 1TB @ ~$80
GPU: Powercolor 7770 1GB @ $157
Case: Sharkoon MS140 @ $52
PSU: FSP Raider 450W @ $68
Total: $696
Buy and build at Tradepac. Squeeze till cannot squeeze liao. :D
MoneyFace =p
Best of both worlds. :s12:
CPU+MB: Intel Core i5-3470 + ASRock B75M-DGS @ $306
RAM: G.Skill NT DDR3-1600 CL11 4GB [Black PCB] @ $30
GPU: Palit GTX 650 Ti 1GB OC @ $184*
Performs near to HD 6870.
25% stronger than HD 7770.
HDD: Hitachi Deskstar 7K1000.C 500GB @ $58*
ODD: Samsung 22X CD/DVD Writer [OEM] @ $20
CASE+PSU: In Win BK644 + Powerman IP-P300BN7-2 300W SFX [80 Plus] @ $100
12.5 litres only.
Even smaller than some of the mITX chassis.
3 years warranty by AIM Resources.
Total: $698
Buy + Build at Tradepac, #05-19.
*Shop system bundle discounts
devil1158
12.5 litres only.
Total: $698
Thanks MoneyFace
ginseng1
I also have 2 sets of Gigabyte H77 mini itx rigs. One with i3-3220 and the other with i5-3xxx. Can't remember the CPU. I still prefer Gigabyte m/b after trying out other brands.
lesliehan
Any recommend of mini itx rig for pure surfing net and HD movies. Rig directly connected to LAN and placed at permanent spot in the bedroom. Don't need cd-rom, wifi, graphic card. Budget as economical as possible.
nippp0n
Do you need OS?
coyote
AsRock B75 ITX + i3 is more than enough.
lesliehan
G2020 vs 3210 differences? Last thing i dont wanna see is that 2020 lags on me on my HD / 4k shows.
