anirudhks
- Jan 28, 2013
Where you transfer to?
from my PC to ext SD
Samsung is more about their spec than the design, sometime i wish they could put a bit more effort in the design department. I have been using S2 then S3 and when i saw the leaked photo of S4. Well it might not be true but i got a feeling that it might just turn out to real and we have a S4 that looks like a note with better specs( i am sure the specs will be really impressive)
Now a owner of Xperia z. What a Beauty. You see this Samsung you need to fired all your designer for your mobile department.![]()
to be frank,i dun use my smart fone for dota,photoshop or 1080p mkv veiwing
as long the looks is nice n the fone nt laggy,it wins me over
can wash under the tap is a bonus la...
but SUXSUNG's plastic really turns me off...
well, i like plastics
theres a difference between build quality and build materials
i don mind plastic as long as it feel solid in my hands
1. plastics are light
2. are replaceable (backcover)
3. will not crack when dropped
these 3 things unibody phones these days cannot do
try use msc mode to transfer....MTP mode is caching mode...
Reason I am not using MTP is i dont wanna open the flaps to transfer data via cable ,so I chose wireless method...
any other way?
Here is my 2 cents to your points.
1. Light plastic but overall phone will still be heavy.
2. Other materials also replaceable at service centre, unless you DIY.
3. Plastic will also crack when dropped, although it gets an ugly dent or chipped most of the time.
Airdroid or FTP... airdroid is easier to use IMO but I feel ftp is faster.
I got a update notification on my hp n said it can only be updated via pc... I usrd both my home pc n work pc but the update stopped halfway n failed...
e update notification stil there... Anyone has this issue?
The problem is with airdroid which I am having when i transfer files album or movies dont detect the newly added files , I need to go file manager and open the files...
hope its 4.2![]()
Ya, understood, restart will do the trick but it is troublesome having to do that everytime, I hope they can fix this in next patch. You wont have issue if you are using 3rd party album and players like MX player...
hope its 4.2![]()
yup correct , or there is also an app to force media scan and get updatd , but the app drains battery as it scans the whole device
