Official Xperia Z Thread
Ah Huat
Hi Ah Huat, see Wolvie's reply to resolve your LED notificaiton issues
I already reset phone once before I root and the led notification light still not working. Now I already done everything up swee swee liao not going to reset it again :s8:
shin7829
YA donno... y.. black spots appearing liao...
u got see the front and the back... that thin shiny purple outline, that outline ur screen.. not the thick side...
i also purple set
i know which part u mean
yes for mine some areas, small dots, paint wear off. if u use fingernail trace, u will feel the uneven surface, use eye see u will know the coating wear off
guess its unavoidable
Just Got my set last weekend.
impression for these few days: the Vibration is so strong!
the vibartion can produce ZZZZZzzzzzzzzzzzzzz sound lol
maybe its on purpose making it so strong
rssd21
i also purple set
My TX vibration also strong, it literally dances on the table when it rings. :D
shadey
i also purple set
People noticed this when using the dock. That's why some of us did the "surgery" to remove the 2 plastic stoppers in the dock. :D
Computeron
No I didn't use dock.
Black will not have this problem cuz the side is rubberised.. Am I right? White I not sure.
GreenHorn
Guys how do you do a screenshot in games? I tried push and hold power button but it does not give me the option to screenshot inside a game.
athir13en
My dock was unable to charge by computer.
but no problem with wall charge..
is there anyway to make it work on computer USB?
Drexter
I just got the Z phone. Any special features other than it is water proof?
Upgraded from a S3.
