[NAS] Synology NAS owner club!
yukita
here is my test:
network saturated i think...
Setup:
DS1812+ with 8x3TB WD Red Raid 10 with Lan1 and Lan2 doing Link aggregation on HP 1810-8G Switch.
Client:
Thinkpad X201 with Intel SSD 320 on gigabit ethernet.
all setup done without jumbo frame enabled.
SpyderMan
Those users with read and write speeds of 100+MB/s, are all your hardware connected directly to the router?
My setup cannot reach those enviable speeds you all are getting. Here's my setup and speed screenshot. Btw, are my speeds acceptable for my current setup? Or can the read/write speeds be improved?
Would appreciate any input or suggestions from anyone. TIA! :)
umpimp
here is my test:
Setup:
Client:
sorry to say speed are slow on Link aggregation
.the speed are same as without Link aggregation
civicguy
Spyder.. My set up is 100% similar as yours.. My fibre connection is in the living room with the router there too.. My switch is sitting in the study room with the rest of the PC/Mac etc and NAS of course....
Except my switch is Cisco SR2016T and all cables are CAT6 (including between living room router and study room switch.. under the floor :) )...
My NAS is DS1511+ running RAID 5
chuan
Hi guys :D Noob here again. Want to confirm before I buy DS413J.
  • I want to connect a NAS to one of the LAN port on the wireless router (4 LAN ports and 1 USB). The wireless router can also act as a switch right? This is the router http://www.tp-link.com/en/products/details/?categoryid=238&model=TL-WR1043ND
  • 3 PCs connected to router LAN ports to access the NAS.
  • 1 Printer connected to the router USB so that the 3 PCs can send print-job to the printer.
Thank you!
quekky
don't think his thinkpad can do link aggregation
yukita, possible to try running the test on 2 laptops at the same time? See if you can get 200MB/s
TopGun
Deluxe Member
PC to the switch is through a single port. Laws of physics can't be exceeded. lol
TopGun
Deluxe Member
Those using UPS, mind sharing the model? Is there one that uses USB interface for interfacing and comes with the normal 3 pin plug receptacle?
echeong
Using a cheap APC BK500EI (~$129) with usb comm to the ds413j,
The UPS back connections look like this:
Using these plugs and old monitor cables to connect:
Front
Back
Old monitor pass through cables
Connection
moozmoow
  • I want to connect a NAS to one of the LAN port on the wireless router (4 LAN ports and 1 USB). The wireless router can also act as a switch right? This is the router TL-WR1043ND - Welcome to TP-LINK
Thank you!
Yes, consumer routers have built in switch.
Yes, 3 PCs connected to router can access the NAS, as long as your NAS is set up properly
Yes, printer can connect to router so that it can be used by the 3 PCs. Can also connect to your NAS if you want, but need additional settings also
hLsY
Have a question regarding UPS.. If the UPS have only 1 USB port, how do I make it shut down more than 1 device.. ?
I have a ds412+ and an iMac 21.5"
Planning to get a UPS, but not sure which one is suitable..
Thanks
chuan
Thank you! :)
Vulpix
Moderator
Moderator
Thanks
Make your NAS a UPS server so your PC can check from the NAS itself.
yukita
that's why i said, limitation on the gigabit :p
my thinkpad only have one gigabit ethernet :D
yukita
yes i can test that... let me find one more laptop to run concurrent test :D
yukita
Manage to find Fujitsu laptop but with normal hardisk. but no screenshot :p
Thinkpad: Write-110MB/s Read-108MB/s
Fujitsu: Write-44MB/s Read-38MB/s
while Thinkpad finish the write and start to read, Fujitsu still writing lol :p there is no performance drop on thinkpad, and if you combine both write, it should hit write speed of 160MB/s but thats still limited by Fujitsu hardisk read speed not the NAS speed or Link Aggregation speed.
conclusion: link aggregation do improve the performance if you have more than 1 PCs/Laptops or your PC got link aggregation/teaming function.
yukita
btw i think you can get 8 port HP switch at $130 which can support Link Aggregation from blue forum (if im not wrong). the HP switch i use, cost $199 from media pro and comes with lifetime warranty.
