Hi all, im trying to recommend an auntie friend of mine to switch from her iphone 4 to Xperia Z.
But i never used apple before, so i need some advice on how to transfer her contacts from her iphone (in advance, as in she might wanna trade in her iphone) to the new Xperia Z?
it doesnt work the same way like android phones where we back up our contacts to our gmail account right?
please advise.
Thanks![]()
please advise.
Thanks![]()
ya lor, apple jin sian de, simi sai also must itune itune.Itune can sync contacts from google. Then when change to xperia, just sync back to google lor. The most simple way, dun need to download anything, dun even have to install PC companion. For iphone, itune is a must (for most anyway). Just use that.
please advise.
Thanks![]()
btw..anyone has the same GPS issue as mine?? and work like mine?? the icon will disappear after map are closed.
XZ users is this true, the interface lag is due to sony UI and when switch to nova launcher, the XZ fliess???
gvgt!
Sony Xperia Z In-depth Review And User Experience - YouTube
Usually sony ui is quite smooth unless you use some downloaded live wallpaper.
Really? Is this a feature of jellybean?This is normal!
The GPS sign disappear when not in use.
I leave my GPS on all the time, It will auto appear only when I use any GPS Apps or navigation Apps (Maps, Papago, Gps status...)
Yes, I agree too. If you say that by default and out of the box, it lags then it is still reasonable but when you load this and that then you start complaining that it lags then it is user's fault.
Unlike one of the brand, it already lag by default without loading anything, you should know which brand I am mentioning.
1) Firstly, use the touch capture instead of the button. Surprisely, it looks better. I think is the focus point issue
2) 2ndly, depend on situation, esp low light, auto may not be good choice, use normal, on hdr, touch capture, adjust ev accordingly etc
Need to play more to know what setting for what situation
3) 3rdly, the burst mode seems to be good for certain situation like moving obj, but havent try that
basically practice...somehow i feel that my pic getting better after advise.![]()
Thanks for the tip.
Btw, does anybody realise that when you are on normal or superior auto mode, the phone will auto take photo when the button is not pressed?? I have this issue most of the times.
nothing weird, it just means nova is a better launcher than sony's.I wouldn't say is user fault, as this is a smart phone, its suppose to let user install whatever **** u want. Whichever phone manage to keep it not lag after all the app installed will be the champion. But lag straight from box is a loser. Haha
Btw, really much smoother with nova. Weird.
There is a new firmware update for our phone, Version 10.1.A.1.434.
