Gribber
- Apr 6, 2012
sorry to say speed are slow on Link aggregation
.the speed are same as without Link aggregation
2 to 1 = slow?
btw i think you can get 8 port HP switch at $130 which can support Link Aggregation from blue forum (if im not wrong). the HP switch i use, cost $199 from media pro and comes with lifetime warranty.
I think my solution a bit more elegant looking.
Using a cheap APC BK500EI (~$129) with usb comm to the ds413j,
The UPS back connections look like this:
Using these plugs and old monitor cables to connect:
Front
Back
Old monitor pass through cables
Connection
Pardon I dunno the PrtScrn combo for bootcamp :/
Here goes with the same test parameters
I think its time to upgrade your router/cables?
Of cuz the difference is mine is loaded with only 1 x 3TB Green on SHR. Maybe more resources available for the system.
Spyder.. My set up is 100% similar as yours.. My fibre connection is in the living room with the router there too.. My switch is sitting in the study room with the rest of the PC/Mac etc and NAS of course....
Except my switch is Cisco SR2016T and all cables are CAT6 (including between living room router and study room switch.. under the floor )...
My NAS is DS1511+ running RAID 5
Similar setup too? Ya, your switch and cables are different from mine but still mine are gigabit capable right? Hmmm...still wondering why my network cannot achieve the speed you guys are getting.
Urs is a 2 disk version right ? I wonder if that matters ? Mine is a 5 disk version.. sorry, pretty noob on RAID...
Where can I buy this? Looks like quite an elegant solution.
Sim Lim Tower B1. At least that is where my friend claimed he bought.
Ohh ok. That means I got to go down early on a Sat to hunt for it.
Just 1 question: No concern on overloading if connecting this extension to the ups?
Can tombang if you find it?
Kamsia
im not too sure, but one of it its like end of life already (if i remember correctly)Can you share what are the key differences between the HP 1810 and 1900 model, apart from the warranty; 3 yrs vs life time.
well, hp procurve switch is one of the best another brand will be cisco, but please dont confuse with "fake" cisco aka cisco small business switchexpensive
they are on different level one.
