First timer in dilema, pls help
essilor86
Hi, first timer here and I am in a dilemma, hope someone can provide advice.
My first choice of flat is a BTO in May 13 while my second choice is the current skypeak at Bukit Batok.
I don't know whether I should apply for skypeak first or wait for May BTO. My main concern is if I wait and apply in May and don't get selected then I end up with nothing. The May BTO for my choice only got 470 units with 2-4rms
Has anyone faced a similar situation before?
keithster
Apply for skypeak first. See whats ur queue number then make ur decision. Now too early to decide cos u hv nt even get a queue number. If u dun like the queue, u can give up.
MBoI1986
If the current queue is bad, no penalty, but if the next bto also get bad queue, will get penalty or not?
Artie
As long as u have a queue number and u didn't turn up for the flat booking, it consider as 1 reject.
First timer have 2 chances of reject before u are downgrade to 2nd timer status for 1 year.
Disadvantage of 2nd timer is the % of all allocated units are 5% in mature estates and 15% for non-mature estates.
MBoI1986
Let's say the number of flats are 200 units, i'm given with 450 on ballot and I'm not able to select a unit. Its considered as 1 reject chance?
alpc
Er, nothing to do with queue - it's when you got appt for selection and you don't turn up, then it will be considered as reject.
victorian07
Nope, if you didn't even get a chance to get a appt date to go down and select - it's not considered as a rejection.
MBoI1986
Thanks for the information. Meaning if there are still available 4 room units left, be it low or high level, we will be called for the appointment based on the ballot queue.
keithster
oh ya... u r right about this... i forgot =:p
