Try deep cleansing shampoo. It really helps.
thanks! any idea where to get it and how much?
u can see her status in her blog: Hair By Shua
What are her rates for men's cut? Her blog post on perm is tempting... haha
Any good places to cut in West side?
Typical answer will be hair spray. But hair spray can be expensive if you keep spamming it, not to mention the headaches that you will have if you use too much of it.
Consider using hair powder/saltwater spray to create hair volume. Pour a bit of hair powder onto your palms and rub it. Then style your hair accordingly before applying your usual wax/clay. U will see how your hair volume is automatically created for you. Then style it as normal with your wax/clay and u definitely use lesser wax than normal. Do not underestimate hair powder as it can be really strong. And hair powder is self explanatory. Being lightweight, it will not pull down your hair at all. So you will have no worries about not lasting through the entire day then.
P.S. Do not use hair powder and saltwater spray together. They are substitutes not complements. If u persist in doing so, prepare to stay at home after doing it.
You can try Shirley Mah salon around Lakeside area. Recommended by friend to try it out. Hairstylist name is Ivan. Google for shirley mah and you should get search results pretty easily.
What's the difference between osis dust-it powder and the salt spray?
Find that dust-it feels a little stiff, so I use mousse instead for the volume.
Saw on youtube that u should use salt spray only once/twice a week due to drying effect.(my hair is also quite dry)
Any difference between the 3?
u also mentioned deep cleansing shampoo, heard that its not recommended for dyed hair correct?
Those $10 cuts I had at neighbourhood always cut one side long and another side short
Erm,
Kobayashi pricing is $50 per cut right? Any recommended hair stylist to choose if I wanna cut mallet?
Is the Shua lady recommended to cut at her place?
The pricing at Kobayashi depends on the hair stylist ranging from $28 to $50.
Any recommended hair stylist over there that you know of cuts nice mallet?
i think they meant mullet.Sorry but can someone tell me what is mallet hairstyle? Cant seem to find any relevant search results when i googled it.
Just now went to Kobayashi cut hair. Cut by this female hairstylist. She's located at the 5th level branch. She cut really to my liking. This $28 quite well spent. Don't really know what's her name though. Her name seems Vietnamese to me.
