Tyre air pressure
lolwtff
Hello, just want to ask if its ok to pump 5-10kpa above recommended air pressure on the sticker? And how often to pump air?
Dragon
Administrator
Yes it is ok. I pump every 2 weeks. Hope this helps. :)
AL5509
Think recommended once a month as I read somewhere but I try to pump weekly as to spot if there is any leak, imagine your tyre is spotted with a leak 1 month later??
o_O
As for tyre pressure, may stating down your profile so can discussed based on your tyres' spec.
If not, abit more always sound fine to me.
Hope it helps.
d3n
I pump 20 to 30 above
i heard pump too much no good... cos the contact on the ground will be lesser... grip wun be as good.
i only pump max 10 above the recommended (cos i upsize my rim by 1 inch).
ValentinoRyan
Ya i got a question.. Im running 215/45/17" for toyota allion. Whats the optimal pressure to look for ? Bcos stock was 14"
Advise plss
HeadQuarters
o_O
Yeah, once i was pumping the tyres when i heard a hissing sound from my left rear tyre. Then i spotted a nail stuck on it. Since tyre was still well-inflated, i supposed must be a fresh wound.
Heng petrol station got a workshop. Quickly went to mend. $8. :o
AL5509
Bro, you are really super heng!! :)
so drivers on the road do not bother.
Even seem once driving with a half inflated tyre.
Do not know if he get to feel any diff?
But if doing that for 1 month, am sure the pocket will feel it....
:p
AL5509
ValentinoRyan; said:
Ya i got a question.. Im running " for toyota allion. Whats the optimal pressure to look for ? Bcos stock was 14"
Advise plss
Mine is 225/45/r17 and am doing 240 psi.
Feel fine to me up to date.
NovJoe
No problem one.
My tyre 195/55/15 on PS3s and I pump 250psi front and 245psi rear. Doing this for years liao. Only dulan that everytime go back BM for servicing, the SE will reset back to 220psi all round...
HeadQuarters
:p
I kenna honked by an annoyed driver waiting behind me to pump tyres coz i dashed off to the workshop to ask if they do mending. :o
HeadQuarters
I used to pumped once a month... My Altis tyre pressure will drop to 190+ from 220...
Now Civic like can stay at 220 for a long time... Maybe becoz tyres new...
Dragon
Administrator
Probably because your tyre valves are new. :)
d3n
Advise plss
there is a recommended air pressure stated near the door there... think u can try add 20-30 more then the recommended?
CCCustom
I'd copied and pasted this from a tyre FAQ in a thread some time last year:
Standard passenger car tyres (i.e. non-XL tyres) load ratings are measured at 35psi = 241kpa.
I don't recommend pumping any more than 35psi/240kpa though, because that will give you an overinflated tyre with uneven wear and reduced grip/braking.
