Recommend GFX for 2560X1440 resolution
fitlies
As per my title, I would like to hear from forumers on the best bang for buck card to support for this native resolution.
I currently am using a FSP 550w PSU, so I hope the new card does not require me to change my current PSU as well. :)
Vulpix
Moderator
Moderator
At that resolution I am pretty sure a bare minimum is a 7970 or GTX 670. There's no cheap way to do 2560x1440 if you want to at least have above 30 fps.
fitlies
do you have a budget limit? :look:
I didn't put a budget limit because I do know that the cost is going to be high(er). Reason I put 'bang for buck' is because I know GTX Titan will not fall into this category :D
Yes, I do game with the most graphic intensive one being CoD/Battlefield series but satisfying the FPS for them is not my top priority.
Can I safely say that the choices will be boiled down to either he red or green camps of 7970 and 670 respectively as the bare minimum then?
Vulpix
Moderator
Moderator
You mean you are ok with low fps in games?
widman01
best bang for buck for me is always ~$150 gfx... :s13::s13::s13:
koroshiya8
2560 by 1440 is no joke in terms of GPU requirement.. just read any reviews of games and the FPS drops a lot from 1920/1080 to 2560/1440 on the same settings... so if u got such a high res monitor you should try to match it was at least a 670.
fitlies
I wouldn't say I don't mind... but I don't know how to put it across here. What if I put the budget at max $600 tops, does it help?
Oh yeah, I'm on a mini-itx platform so probably a rear-blowing card would probably be better for heat management/ventilation a little.
Hahah, I get you bro. I myself was using a second hand mid-tiered card previously but guess going for a change now.
$150 gfx can support 2560x1440 meh?
Vulpix
Moderator
Moderator
150 sure can support. Just that don't expect any miracles when playing games. Anyway 600 can you a nice 7970 3gb sapphire or gtx 670.
fitlies
Any reason why Sapphire 7970 and not the rest of the non-ref cards? How about an option from the green camp then?
Vulpix
Moderator
Moderator
Just a brand preference thing. You can pick other brands.
fitlies
Just humour me here: what 670 or 7970 card will you get if you were in my position?
junialum
I got the GTX 670 to run my 2560 x 1600.
Palit Jetstream cause it was cheaper and I don't expect to use it for >2 years (2 year warranty is the caveat). Also, this forum isn't too fond of Palit. Heh :)
ASUS and MSI are the recommended brands.
fitlies
Ok to humour u. Go get SLI titan. Lol
Certainly you don't get my 'humour' there my friend.
No worries, my first card was a Palit too. The shorter warranty certainly warrants a lower price; makes sense. Twin Frozrs and Direct CUs are solid no doubt.
And in two years time you expect to run at a higher resolution? :s31:
hmm maybe can consider the 7950 3GB lor
Great! Although games may run at a lower FPS and it's not really 'futureproofing (subjective)'
After some reading, I'm somewhat leaning more towards the green camp though. Word has it their cards are more efficient.
