leejhong
- May 30, 2007
Same situation. Vivian commented my hair is very fine, machiam like baby hair. The way she do is to use volume mousse on wet hair then blow dry. Afterwhich use wax to style and can use spray to fix it.
Something to do with the mousse giving extra thickness to the fine thin hair
Depending on how you spray OSIS+. It can be very strong but if you spray it at relatively close distance, it will definitely pull your hair down. Imagine the spray takes some time to dry up and it will naturally pull it down for sure. Use a lightweight spray instead.
Also, only explanation for your problem is your hair is too fine and straight. Try switching to other brands of wax that better suits your need. Sebastian craft clay is not really suited for people with thin and fine hair. It wont hold for long on fine hair. Syoss tu-re design controller HARD should be able to help you. On a side note, kudos to you for using sea salt spray/hair powder. With all these, its kinda impossible for your hair to collapse.
