ping to router.
ry0suk1
My ping to router is 1ms - 9ms using cmd to Test. Using wired connection. Router is asus AC66U.. is this normal? Tested with 2 pc wired 1pc using 1m lan cable cat5e another using 15m.. is there something wrong? Tried resetting the router but still the same. Is cable faulty or my router faulty?
HeeroYuy84
U never tell us your testing results, u test 2 over what results??
omega_
A latency > 1ms is not normal on a wired connection.
You might want to check the load averages on the router and see if there's anything hogging the CPU cycles
ry0suk1
I saw online some of them using the beta firmware having similar problem.. could it be the firmware casing it?
ry0suk1
hmmm back to .270 firmware, everything back to normal.. seem that .354 is having problem now.. even with the latest merlin firmware that using .354.
perperdino
I just tested mine as well..im not getting my >1ms even on a fresh router..
I had mine replaced 1 for 1 thinking it was the router defect.. but it seems to be the same.. my wireless is choppy.. my wired is bad..
This doesnt seem to worth 300 bucks at all..
feintan
Is it overheat? Try bring down the heat and try again
perperdino
no its not overheated.. temp is 40-50degree
my wifi ping to router is horrible.. it spikes @500-1kping for VERY long like almost 5minutes if i dont do anything about it..
i dont have interference at all
the wired ping to router can be stablized at <1ms if i use the normal fw instead of the beta fw
but my wireless is still horrible
perperdino
screenshot your settings?
i am sure it is not over heating
my connection from my router to modem is fine as well..
it's only the connection from devices to router thats cranking up
the wifi always shoots up to ~1k ping during usage
feintan
Try uncheck the b/g protection if u don't have any b/g device.
perperdino
my laptop shows fine <1ms to 5ms
my desktop has games on that and currently the ping is 900~
however if my laptop were to turn on applications as well it will shoot up like the desktop..
the ping rises on usage.. is there anyway around this?
i did a 1for 1 exchange for my ac66u so it shouldnt be a hardware problem
