ping to router.
perperdino
what game are u playing on the desktop?
what apps did you start on the laptop?
desktop and laptop on wifi?
yes both on wifi
i play neverwinter night on my desktop + Steam somehow the problem arise when i have too many connections and is fine when i jus have 1 game on..
my laptop just surfing and streaming music/videos.. chrome with too many streamings would cause the ping issue
well my older weaker g router can support 3 different games without my wifi cranking up
cyberet
yes both on wifi
not sure why your other router has no issues
although i think it won't work, but you could try the following and see if it helps.
use back .270 firmware.
disable TX Burst
disable APSD
change DTIM to 1
if still cannot resolve, then sorry, I'm out of ideas :s13:
perperdino
disable TX Burst
disable APSD
change DTIM to 1
:sad: doesnt work
fleas1
try a wired connection to another laptop directly to the router and ping.
if <= 1ms, then its client having the problem.
if still the same result, try put a fan directly facing the router and full blast. see if there's any improvement.
if not, could be as what people said, firmware.?
perperdino
What do you mean client problem?? My lan ping is <1ms I have fan blowing at my router
But both my laptop and desktop have the same issue.. so both have client problem?
cyberet
eh, u using 5GHz or 2.4GHz? your screenshots are for your 2.4GHz settings
perperdino
yes i use all 2.4ghz cos the 5ghz is not stable at all.. it gives more outage and and ping issue is more frequent
but occasionally i still do try 5ghz to see if it is better..but seems like both settings give me this ping spikes
if there isnt any fix i think imight have to refund it..
any other router recommendations?
perperdino
Netgear R6300?
anyway just to make sure, your router QOS is disabled right?
yep all disabled.. i dont even need my router to do dns or anything no need firewall on as well cos after my router is the starhub's huawei as a bridge
this sucks spend 300 bucks but the wireless not up to standard
cyberet
you pinging 192.168.1.1 (huawei?)
your ac66U is set as 192.168.2.2?
What's 192.168.2.1?
feintan
Switch off the huawei wifi. It might interfere. Or any cordless phone nearby.
deathblade82
i am sure it is not over heating
my connection from my router to modem is fine as well..
it's only the connection from devices to router thats cranking up
the wifi always shoots up to ~1k ping during usage
Hi
From your SS that u had provided, I am suspecting that the 40mHz wide fat channel might be culprit. Below are some of the setting/changes that I advisde you to try out. I am also using these settings too.
1. Wireless mode: N only (if u do not have any other b/g devices)
2. Chaneel BW: 20mHz
3. Control channel: 1
4. Preamble Type: Auto
5. DTIM Interval: 1
6. Enable TX bursting: Disable
7. Enable WMM APSD: Disable
Other than these, I see no issues with them. After applying them, do a reboot of the router to play safe.
perperdino
My 192.168.1.1 is my ac66u 2.1 is my huawei.. huawei has no wireless all off.. that 1 setting I know.. im pinging direct to my ac66u.. I do have basic it knowledge ..I will try 20hz later and see the results..
deathblade82
Do u noe ur stuff well or not ? From ur SS, u set ur AC66U to be 192.168.2.2 gateway to 2.1. From this, ur router is 2.2 and huawei to be 2.1. Pls do note that ur subnet mask also play a part here. X.X.1.X and X.X.2.X with the same mask of /24 are of 2 separate network.
