Official Xperia Z Thread
Computeron
ANY 1's XZ facin alot of dirt trapped on ur inner screen protector and the thin dark line around the screen?
doki81
meeee!! cos i always store inside pant's pocket....it's very hard to clean it unless wash with water :D
Computeron
si bei sianz sia.. even my sp also tio.. i notice many sp is slightly 0.1mm larger... hence it also tio the dirt from the black line... now my SP got one white (dirt) lining all around...
feel like removing the anti-shatter film.
Layers
how to prevent this dirt? put XZ in a pouch?
carlover76
battery drain not really that much....the smart watch only connect to your phone once a while...
i am thinking of letting go my 1 month old ++ smart watch with superb sui price :p (bought in changi duty free shop but end up dont have duty free...)
getting myself pebble and it's arriving next week..
Brother, how come you go for Pebble Watch, it is just black and white display? =:p
Turquoise!
Got a long scratch across my screen last week unknowingly, just by placing my phone inside a pocket with nothing but my phone in a bag.
Thank god it's on the SP =:p
Tuakong
Pebble watch batt is good BUT it will only display LATEST notifications. If you have 3 incoming SMS, only the latest will be displayed and it will auto-delete after 3 minutes. You cannot retrieve past notifications from Pebble.
I am not sure about the Sony but I believe it does provide on notifications and u can review past ones.
Catlover76 bro, can to comment?
carlover76
Brother, you are right.
You will be able to view the latest messages and even after 2-3 or more messages provided you do not switch off the Smartwatch for that connection then you can view all messages during that connection period.
With the SmartCamera app from the Playstore, you can remotely take photo, preview the photo and delete the photo taken from the phone on your SmartWatch, guess you will not able to do so much function with the Pebble Watch.
Tuakong
Bro, I may be getting the Sony later today.
Just to check. If the BT connection breaks between watch and phone, do I need to 're-sync' the notifications/alerts when watch is reconnected?
What is the batt life on the Sony?
I am getting it as a weekend watch..Fri-Sun and for travels. As for charging, my plan is to charge it every nite.
carlover76
No need to resync, once it is disconnect out of range and when within range, it will connect back. All the settings can be done on the SmartWatch app.
Battery life of the watch will depend on your notification duration cos when you have frequent notification of your messages, battery will drain faster which is normal as it will vibrate at the same time. You can also configure it not to vibrate if you do not want so it all depend on your own setting.
carlover76
ok thanks, Carlover76. Slightly off-topic in this forum....solly :D
Ok la. Once you get your SmartWatch, you will love it and even my current set is spoil cos it is more than a year already. I will also buy back the same SmartWatch unless they have new model later.
OnLyOnE
I don't know if this has been asked before about the camera. I've disabled Superior Auto mode and uses only Normal mode. However whenever I start the camera from the quick launch (from lock screen), it always go to the Superior mode. When I exit and start it again (not from quick launch), it will revert back to Normal mode.
To me, Superior mode is inferior and this behaviour is kinda irritating.
Anyone has the same issue?
Not sure if anyone have answered you. My solution is that I got 3 shortcuts on my homepage, burst mode (day shoot), normal mode (night shoot) and video mode. Nowadays, I dont use the quick launch mode because it is annoying.
hueman
OOoo.. how did you do it?
Tuakong
Just bought it and I personally find it cool contrary to the some negative reviews
It meets my needs so I like it.
If only the weather app could support more cities.
carlover76
Told you that you will love it, I have been using the first version of SmartWatch from SonyEricsson previously which is called LiveView and it is not so good and this 2nd version of SmartWatch is good. =:p
FiSh_23
anyone knows what is the price of XZ from M1 currently? wanna hoot one and join u guys leh. haha
