Mining PC - Comments / Thoughts
Preety
Motherboard ASRock 970 Extreme4 / GIGABYTE GA-990FXA-UD5
Processor AMD Sempron 145
Memory 4GB G.SKILL DDR3 SDRAM (2 x 2GB)
Power Supply Seasonic 860w Platinum PSU
GPUs 3 x Sapphire HD7970 3GB DDR5
Thoughts comments?
This is not for bitcoin...but for litecoin/feathercoin...
Preety
ASRock 970 EXTREME4 ATX AMD Motherboard with UEFI BIOS - Newegg.com
Your second and third card may be a bit close. You will need to get good fans and a well designed chassis to keep it cool.
860W is enough for 3x 7970? You may want some spare capacity due to heavy usage. I know it is a Seasonic Platinum but I still prefer to err on the conservative side of power consumption.
How about seasonic 1200?
BTW you linked to Newegg, is there a way to get it shipped? Cheaper with newegg + shipping to Singapore?
Maeda_Toshiie
My intention for the newegg link is to illustrate the PCI-e slots.
Regarding PSU sizing:
Overclocked! GPU, 1200W++ on synthetic loads!
Real World Trifire 7970 Power Consumption Recordings. - AnandTech Forums
Long thread on OCN:
Trifire 7970's...1050w Enough?
Gaming will draw substantially less compared to synthetic, especially when the CPU is the bottleneck. Since you are doing mining, your load is most likely closer to synthetic loads.
One config at Hard. Synthetic benchmarks can drive power draw past 1000W.
Real world power consumption measurements from triple 7970's
The values are drawn from the wall, so efficiency must be factored in. Plus, kill-a-watts are known to give inaccurate readings. I don't know how well coin mining software loads the GPUs. If they load them like benchmark software does, then a high quality 1200W is probably a necessity.
With regards to buying from Newegg or Amazon:
Why SIngapore retailers or distributor charging us a premium?
I've not done it myself, but some use VPost, though I've never done it before. Yes, there is the shipping, which may negate any price difference. The other issue is with warranty and RMA.
BTW, Newegg is not the cheapest in the US, since physical stores like Microcenter (and maybe Fry's) are known to sell cheaper.
According to the VR zone thread I linked, you can get cheaper hardware from Malaysia or HK.
Cookiejar
While feathercoin and litecoin are still new, you should be rushing to set up your hardware.
IDK how long it would take to get a coin now, just thinking that they are still relatively unknown and good for early adopters. Saving a hundred or two buying from newegg might not be worth it if you could have mined a hundred coins while waiting.
terence52
Maybe I should do litecoin or feather coin. Already have 2 7970s on standby.
Anyway. Best to get a 1kw. 7970 consume a huge amount while running at 100%.
Preety
Thanks Maeda_Toshiie...
Where do you recommend i make my purchases in KL? I am heading their next week...what are the best places to buy that are reliable?
Maeda_Toshiie
Sorry, no personal experience nor know of anyone who does so. I'll let others chime in on this.
Preety
there are few Jayacom, Cycom....looks like there is Sim Lim Square equivalent...
Plaza Low Yat, 55100 Kuala Lumpur, Malaysia
Kiwi8
Deluxe Member
I have a HTPC that's run 24/7. Is it ok to use it to mine without affecting the recordings of TV programmes? :o
Preety
is it still profitable as of now?
well the litecoin and a couple other secondary currency may have the potential...
it has its risks, but like the bitcoin, its exchange rate has also soared...maybe it rise further..maybe fall...
Litecoin was 0.06947USD in the begining of the year...
now its about 3.24USD (12-May)
betadyne
So how long do you need to mine to get back the cost for the equipment and electricity?
Preety
Assuming a rate 3.3 USD for HTC we are looking at about 250 to 300 SGD a month as profit. So a break even at five to six months.
Preety
Best scenario to hoard the coins for now and sell it later when price goes up. And then you can also harvest the rig to get some more dollars
archcherub
Moderator
Moderator
it would be great if prices keep rising.
but must bear in mind if prices collapse or electricity bill rises.....
maybe can do those mobile laptops then can go coffeebean sit in... HAHAHAHA :D
Preety
oh yes...its a risky proposition...if you compare then stock markets would be a safer bet :)...
zero7090
860W is enough if PSU is single rail and 7970 run @ 1.2v max
oh yes...its a risky proposition...if you compare then stock markets would be a safer bet ...
when stock crash you have nothing but paper, when crypto crash you can sell the GPU and PSU to recover loss.
Let not forget that all you only need to set up the farm stable. After that, it will run 24/7 earning you money while you sleep.
