Xperia Z Question
Carcharias
Hi all,
I just jump ship from HTC to Sony. The android UI is a little different obviously. One thing I couldn't seem to figure out is:
- when we put songs into the phone thru usb, the songs does not auto appear in the list of ringtones. I've put the songs in the "ringtones" folder as per what is taught on the net. It still doesn't appear.
- we can use a bypass method through the music player -> set as ringtone. Fair enough it works.
- now, how do I use such songs/custom ringtones for specific contacts? The list still doesn't show the songs. -_-'''
If you could help me with this, I would be very grateful.
Many thanks,
Adrian
glabejut
download es file explorer from play store. whenever u want to choose a ringtone, it will ask u how u want to pick the ringtone, select es file explorer and u can choose any files from the storage.
glabejut
sony stock photo widget is quite good? unless ur not using the stock launcher then idk. not using any photo widgets. =:p
hush66
Thanks all.. What about any photo frame widgets? Just like the ones in HTC..
You'll have to find your own photo frame widgets from Play Store.
Regarding the ringtone issue, are you sure you've placed the ringtones in the correct folder? I don't have an issue with assigning ringtones. I simply created a ringtones folder in the root of my SD card and placed the file in there. You can also create a ringtone folder in the root of your Internal Storage and placed the file in there.
rssd21
The phone can detect your music files anywhere in the internal storage or msd card.
Just make sure the music files are supported by Walkman, meaning mp3/aac and not other files like wma which are not supported.
If the music files are located in msd card and not detected in Walkman app, you may need to format your card using your phone or change a new/good card.
Carcharias
Ringtone done correctly leh but still cannot.. Anyways the Es file program does the trick too.. :)
Carcharias
are u using the stock launcher?
Yup, stock launcher.
Anyone using any lock screen tools? Alot of the lock screen tools seems to "on back" the screen after I press lock. And there was one where it seems to lock it and off the screen already but the back light is actually still on. not sure if anyone experiencing the same thing?
hush66
It's a Jelly Bean issue.
Carcharias
Sorry, it's a Gingerbread issue. It has been there since Gingerbread rolled out and affects other brands as well.
i didn't notice that on my htc one x.... thanks for the info anyways bro.. meanwhile can only press the power button.. zzz..
David Lai
Hi TS, borrow your thread to ask a question yar.
I've turn on dial pad touch tone, but the volume is very soft.
Possible to adjust it louder?
hush66
Help help!!! My Xperia z went into infinite reboot after I update the firmware yesterday. Any solution to get it out of the reboot??
You post in how many threads????? See my reply in the other thread.
