sAxman_Returns
- Dec 21, 2005
Borderlinx users take note.
If your US purchase consistently comes in bigger
box then usual, regardless your items is big or small inside the box please post your description here for awareness.
I have had two small items from Amazon which weighs less than 1kg now becomes more than 2.5kg when arrived at my suite. (And yes I know what is volumetric weight.) And it seems every item you bought big or small will be at least 2.5kg when arrived at Borderlinx.
Amazon packing is usually within reasonable estimation depending on what your items are. For example. I bought a small item and the box is only 1/6 the size of a tissue box. But it came with a shipping box which could contain more than a dozen. I bought the same item last year and it came in a much smaller shipping Amazon box.
My past experience with Amazon packaging has been realistic and expected. Now it's getting very suspicious when arrived at Borderlinx. Everything is now minimum 2.5kg. So take note and take care of your wallet.
are you talking about amazon only or everything to borderlinx?
my active parcels with them now, smallest is 200g....
Anyway, what's the current promotion now? Got $5 off or something right?
