The Intel LGA1150 Haswell Owners Thread & Survey (H.O.T.S)
Are you buying Haswell? If possible, explain your choice in a post
  • Total voters
    275
Nickzz
Haswell revolution.
junialum
Waiting for all the first round benchies, comparisons of mobos! Here comes 3-4 months of mobo research for a possible i7 4770k purchase.
muddle
K cpu also cant oc that high. Tink better get non k version with the h87 mobo
aCuria
Ya I agree. I also prefer that they gave us 6 cores, but then that will just eat into the E series, whatever that is supposed to be called. Intel's marketers got us by the balls. For me it's either MSI Z87-GD45 Gaming or ASRock Z87 Extreme 4. Slightly leaning towards the MSI due to the Killer LAN (although it might turn out to be snake oil). I condemned ASUS liao due to their lack of innovation as well as super ulu service center. :mad:
Also looking for my next PSU. I want a platinum but all the platinum PSUs too high wattage. I measure that my system's load power draw with my current system is typically 250W, so my optimum PSU wattage is 500W~.
Oh ya. Haswell SKU. Probably i7-4770 non K for me. The K processors do not implement the new Transactional Synchronization Extensions (TSX), which might be helpful for multithreaded workloads.
Where did you get this information from? is TSX implemented on ALL non-k haswell skus?
Edit:
I found it, you are correct, TSX is NOT IMPLEMENTED on the k series skus. that is such a bummer. How they can remove features and charge more is beyond me. TSX is like the most interesting thing haswell brings to the table.
http://ark.intel.com/products/75123/Intel-Core-i7-4770K-Processor-8M-Cache-up-to-3_90-GHz
snipes14
Edit:
ARK | Intel® Core
Yup, it seems that if a CPU is a K series then TSX is not present. However two non-K CPUs don't have TSX as well: The i5-4330 and i5-4330S. I got my information primarily from this table here:
Core i7-4770K: Haswell's Performance, Previewed : Core i7-4770K Gets Previewed
Unfortunately it's a piece of information that not many sites cover.
I think Intel is causing quite a bit of confusion with their products like this, as what SKU has TSX or not is quite arbitrary.
duffie
Edit:
ARK | Intel® Core
Not really a bummer, they always do that. They crippled the i7-3770k as well.
m3 th3 last
May i know whats the highest clock non k can achieve? Thanks.
2 Piece of article you should read
http://www.tomshardware.com/reviews/core-i7-4770k-haswell-review,3521.html
http://http://www.anandtech.com/show/7003/the-haswell-review-intel-core-i74770k-i54560k-tested
Think around 3.9 ghz (base is 3.5) on air with 1.2v, based on what i have seen on tomshardware and anandtech.
However they did not show the temperature so i dare not say much, earlier Chinese website stated that using the stock cooler provided by intel u can't overclock much as it generate much more heat compared to ivy bridge.
Going wait for more detailed review, as the information now points towards bad overclocking headroom due to the heat generated.
My point is if you can't keep the CPU cool, it is bad for the lifespan for the CPU. U would be better off not overclocking it and get the non "k" version of it. (i am looking to replace my Q6600 also)
Need more inform now, plus motherboard price is so high even while voltage regulator are moved to the CPU. So rip-off right now.
duffie
Is it actually possible to use the internal GPU as a device parallel to a dedicated graphics card for display or will it be switched off automatically?
MacClipper
btw, if you are running stock or undervolting then Haswell load temps may not concern you.
LinX AVX Stock Run
CPU at factory stock settings
10xLinX_Stock_93GFlopsCopy_zpse8e0da80.png~original
HTH
duffie
isnt that the virtu feature?
Isn't Virtu just for switchable graphics? I don't want to switch, I want to keep the integrated GPU as an additional computing device while running a dedicated card(s) as well.
Elijahonli
additional computing then dun think so liao....
if only can use the h264 encoder on the iGPU for video streaming that would be good :D
