Slim MTX Case - Recommend
kawaii_boy
I'm looking for a SLIM M-ATX casing.
I'm don't use dedicated GPU, it just need to host MB, 2.5 Inch HDD and PSU.
What are option avail ? :s12:
kawaii_boy
I'm think I'm will buy this
ZBOX nano: ZOTAC - It's time to play!
rAcEr
intel NUC...SLS selling 449 or cheaper if u dont want the wireless card.
INWIN has a really small casing for SGD99 too...looks very nice if u wanna use it just for HTPC (beware of the noise coming from the PSU though)
coyote
AsRock B75M-Pro + Intel G2030 at S$186.
WD Blue 500G at $72
4G RAM at $46
Cooler Master Elite 361 $59
FSP Hexa 500W at $69.
+ $115 for some Windows OS.
Get the bundle from one shop & get some discount... you can do the sums yourself.
kawaii_boy
I'm have think of using Intel NUC but only support m-Sata :(.
kawaii_boy
I'm refer minimum noise and power comsumption :).
WD Blue 500G at $72
4G RAM at $46
xkiller213
last time used Antec ISK 110 case for a ITX build... nice case, ultra compact and can fit 2x2.5" HDD/SSD...
Kiwi8
Deluxe Member
The $15 casing is not bad if u dun use a dedicated GFX card.
But do note that u will need to buy bumpers to affix if u intend to place the casing horizontally.
