maliciousmonster
- May 8, 2008
Anyone know a good and reliable pc repair shop that wont chop carrot? My cpu died on me last night.
Windows start-up repair won't help at all. Don't waste time on it.
Take out gfx n use onboard graphics n see how.
Clean your pc internals while u r at it.
HDD should be quite hardy bah. What do u mean by hdd also haywire liaoz? What did it do?
Try disconnect the power cord to the pc n connect n start up around an hour later. If can get in, do some backup for ur data first.
Then do a mem test on ur RAM.
If ok, next will be testing PSU...
Used to have this problem on my old rig. Decided process too long and boring to fix, end up build a new rig. Lol.
What is your pc specs? How old liaoz?
Sometimes it might be the batt on the mobo that is dying.. Thus affecting the start-up process also.. So can just change the batt..
wuweiz korkor is good n reliable
so basically you formatted your whole harddisk?
if you formatted your harddisk means everything gone...
need to do fresh install of windows
I where reliable? Sometimes can type wrong things then kena shoot. Lol.
And I not used to people call me kor kor. Kids call me uncle nowadays. Lol
Call uncle weird weird, everyone makes mistake haha
Seems like ur mobo got prob eh or your HDD corrupted.
I took a picture of the problem.
See the blue pixels popping out? It suddenly become like that.. sometimes the colour go haywire too..
After I press "Start Windows Normally" and go to this loading.. The screen turn black instead of the normal start up page and auto restart
Ok, I'll unplug my gfx card and try the onboard gfx later when I go home and probably clean a bit. I probably won't do anything more than unplugging and cleaning cause I'm pretty sure I won't know how to put them back..
You still using vista.. Lol.. Need to upgrade to at least Win 7 if you gonna change PC.. I think newer mobos don't support Vista anymore..
You can even use Win XP with z77 or z87 boards, no such thing as new chipset doesnt support older Windows version.
Im using windows 7 home premium and my processor is i7. The insides are pretty new but my gfx card and hdd about 8 years old. And my case havent clean for at least 8yrs+
do u know the meaning of cpu?
i tot your i3 i5 i7 cpu spoil
