ba200 vs gr07 mk2
Techtard
Which of these is better sq wise and how does the sound compares to my last iem the se215spcand mh1c. Will be using my clip zip which have a ruler flat frequency response.
Phen8210
not sure with clip zip how it sounds.
but both not as muddy as se215.
Both have treble that are more laid back.
In terms of sq both of them r better then se215.
ba200 having lesser bass then gr07 mk2, overall frequency smoother and cleaner seperation.
gr07 mk2 having more and extended sub-bass, mids have more body then ba200.
ba200 Treble wise compared to gr07mk2 is smoother, and more detailed.
Emospence
Both good upgrades from SE215, but GR07 mkii a bit grainy to me, I like BA200 quite a bit more
TeamStereo
Suspended
I feel that the treble on the GR07 has more sparkle too but yes of course overall smoothness goes to the BA200. =)
Techtard
Wow thanks for all the replys, did not expect anyone to care.:)
Just wondering do any of these iems benefit from an amp and also how do
these compare to the westone 2, tf10, and m50(headphone).
Phen8210
se215 is closer to tf10,
the rest are just too different to even compare..
gr07 doesn't really benefit from amp, but benefits alot more from a decent DAP.
BlitzStryker
I think Philips S2 $170+,Rockit it R50 $155,Vsonic VC1000 $160+ and Astrotec AX7 $180+ are good alternatives to Vsonic GR7 MK/BE and BA200.
For more budget conscious,can try Hifiman RE400 ard $130.
* Price wise "agar-agar" from memory and in SGD. Pls double check..
kaixax555
I like both, I find both really similar
find the GR07 a tad more bassy, and BA200 to be much smoother
listen to both see which one you like more loh
both GR07 and BA200 are nice stuff for the vocal lover
LouisLoh
If really want vocals, Westone 2 quite hard to beat. Quite a bit more expensive too though..
tt32003
Which one will give a better fit ?
Both need to hook over the ears ?
Techtard
Thank you all for your replys!
Looks like I am going to get the ba200.
Where do you guys think I should buy mine(No online retailers as I am too young to have credit card:o)
Also if I want to upgrade in the distant future, what options do I have, so far the only good one I know would be the westone 4R.
One last thing, will these lose out to my se215ltd in terms of build quality?
mantisviii
IMO, x10 is better than both of them by quite a margin in everything except durability. It's all about getting them at a killer steal price and taking care of them.
Phen8210
Actually how does the Klipsch x10 compared to these 2 ?
it has the most bass, they are pretty much on par with each other depends on which type of sound u want..
Phen8210
of cos buy from stereo la, btw how old r u?
I think the build quality all about the same, se215 cable is removable btw.
