The Hair Thread - Part 1
netzach
Bro, thats because you are equally friendly as well! Thanks for your praises and hope the seasalt spray will be to your liking! :)
Looking forward to getting more items from you bro. :s12::s12::s12::s12:
BigbiGLameR
Lemme know if there's going to be another MO, esp for hair volume products. In the meantime will bookmark here for more information.
leejhong
Bro, you can always head over to theprettyjerk.com anytime to take a look at the hair products, including volumizing products too!
x3dnd3x
Yeah bro. And thanks for your great support in getting so many bottles in one go! :)
I remember you saying applying sea salt spray need to blow dry that's why now looking at hair dryer. My sister don't allow me to use hers because need to shift here and there, very lei chey.
Can i just spray the sea salt spray onto my head, rub awhile then use towel to dry it?
x3dnd3x
dropped by to give a good review for jhong bro's nigelle clay. it has this unique characteristic of holding your hair without appearing that it's there. gives a natural styled look while being easy to wash off with fantastic hold even with a small amount
may be a bit on the pricey side but every penny is well spent IMO
Bro. Don't mind writing abit more for this product? I'm interested as well but because its a more expensive product, don't wanna just buy like that.
x3dnd3x
leejhong
I think its relatively hard for you to towel dry your hair till its completely dry. So yah, i dont think this method will work. Best results are achieved when you sprayed it onto damp hair then blow dry so you still have to blow dry if you wanna see the volume created. Use your sis hairdryer in her rm then. LOL
x3dnd3x
Arh okay. Nahz, i'll get one myself then. Her mirror is those slanted ones. I don't even know why she got a slanted mirror in the 1st place. :spin:
leejhong
Below is an elaborated description of nigelle bold make clay
Selling points:
- Top grade clay which is non sticky to create your desired texture easily with dry matte finish; Comes with pleasant smell
- Lightweight clay which does not pull the hair down yet at the same time, looking natural
- Exclusively catered to create layered hair texture and tousled look; Fantastically strong holding power to last through the day
- Absolute easiness to style and washing off
- Best for people with short to medium hair length
- Nigelle is one of the premium brands in Japan; Quality is guaranteed
Something you should also know:
- A special type of clay which is soft and wet in nature; Typical clay is dry and hard which could be relatively hard to apply
- Nigelle Bold Make Clay SH does not become firm after application which allows high level of easiness in restyling freely and flexibly
- How long can this last (daily usage): 8 to 10 months
x3dnd3x
You're making me damn gian bro. :(
Try the sample 1st. :o
Selling points:
gaoxing84
Thank you so much bro. So this 3 are the recommended powerful yet affordable ones i believe? :s11:
Yes. I might be going for the first link one. 1900 non ac. Ac motors are usually heavier but their cold hair is really so much better. Good for setting the hair after using hot hair.
gaoxing84
Selling points:
Hey bro, got sample for me to try? Haha. :x
gaoxing84
Anyway, I tried again using my Redken fiber cream, it works well with quiff, total matt look. But I think it's best used with medium hair length. Applied the fiber cream on wet hair and blow dry to somehow a quiff and it stayed. The entire day. No other product. Just the fiber cream. Interesting. Haha
netzach
Hello and no, i don't want you to help me cut hair. :o
Ohh btw, Power nasi lemak reopen liao.
not about cutting hair already bro. just wanna be friends nia :(:(:(
yap yap. hell long queue man, i passed by 6+ yesterday evening, queue almost reaching the road. :s22::s22::s22:
gaoxing84
Bro, i confirm you will like this man. I am working at tanjong pagar now too. Can pass u anytime, bro.
eh work where? haha can text me. you still got my number?
good for quiff? haha.
once i received all the samples, will do a review for all. haha.
so far redken fiber cream is good for quiff. haha.
i never try blowing dry after using scheme cream. maybe should try over the weekend end. same for spongewax.
leejhong
Yes its good for quiff. Gives you a layered texture and a nice matte finish. Just texted you. Take a look, bro! :)
