Dell U2312HM
doki81
anyone has issues using the monitor?
my friend purchased this monitor, connected it via the DVI cable provided to a PC 7850, changed source to DVI, but nothing comes out, only the power saving mode signal
ur fren pc newly setup? is there any on board vga? if yes, try check if the output has been set default to use onboard vga instead of video card.
shadow84
This monitor needs Male HDMI to Male DVI-D in order for it to work, am i right? HDMI is conencted to desktop/laptop, DVI-D to the monitor. Since it does not have a built-in speaker, i need to connect my speakers to the desktop?
Will there be any picture quality compromise by using a hdmi to dvi?
jtjt00
Both DVI and HDMI are digital, quality is about the same.
gladiusgg
Anyone interested to buy my less than 1yo 2312hm? I've upgraded to 27" monitor liao.
tzeminn
Hi,
How are you. I can give you S$170 for it. Same as what some others are selling here. Contact me for immediate deal 97711188.
Cheers.
Sherra
where is the cheapest place to get this monitor right now?
currently using the older version i think, u2311H.
So plan to get another to have dual screen....
LesterQ
What is best buy dead pixel policy? Pc themes is at 7 or more dead then can exchange...
Jas007
guys, when u call Dell that 1800 number that was sic for one-to-one exchange ... how soon/long before they come to your place ?
i sent in invoice as per requested 1 week ago ...
no sound no pic !
i almost forgot i called them even :s13:
haans
Anyone got this monitor from SLS besides best bargain? Fuwell price is just $10 less than dell online at $289. How much pc show were selling? I think I found was $269(not sure).
Was panaroid when read about the back light issues. Why still so many ppl buying? How about asus monitor?
Sherra
erh. anyone just got their panel recently?
My came with backlight bleeding. changed, twice already, still same. Now abit pai seh to call em to change again ..
How ah? hahaha
this batch all spoil one issit
prtscn
Just asking current users of this monitor, cause I'm deciding between Dell 2312HM and AOC 23", what's good about this monitor?
Airekris
It depends on your purpose for the monitor. From what I understand the DELL Ultrasharp series like your U2312HM are using IPS panels. These are highly colour accurate therefore making them ideal for photoshop and other graphical designing applications. However I am not sure what you are refering to as AOC 23" so cant really help you.
G0500474
WTS a second hand U2312HM @ $190. Anyone interested can PM me. Just purchased 2 from one of the brothers at HWZ but running 3 screen outputs is an overkill. So deciding to sell one.
Let me know if you are interested. The bro bought the set on Dec 2012. Thanks.
dmstar
Yup yup.. good for doing graphic designs
Asure7
U2312HM being a budget model is not factory calibrated. Only the more expensive ones with PremierColor are.
You'll still need to do your own calibration (best with calibration hardware rather than "eye power") to make it suitable for graphics design :)
