Cryogenist
- Jun 12, 2005
Hi guys.
Just wanna share with you guys on this Memory Leak ONLY in Windows 8.
Not sure any of you heard of it or got it before.
I gotten it a few times and finally managed to resolve it.
Apparently this guy below
"Windows Network Data Usage Monitoring Driver" or NDU.sys was introduced in Windows 8.
Info:
Windows Network Data Usage Monitoring Driver - Windows 8 Service - batcmd.com
This guy is pretty naughty and causes memory leak.
It is being reported in a few places below:
Discussion Threads
Non-Paged Pool Leak in Network layer
Windows 8 high memory usage - Windows Discussion & Support - Neowin Forums
Damjan's playground: Windows 8 RTM Memory leak - NDU.SYS?
This screenshot is gotten from Damjan's website
Causes
The exact criteria to trigger is not confirmed 100% though.
Some were pointing at the Network Drivers.
Like what some say, is probably a VERY BADLY written network code by dear Microsoft.
This guy will cause the "Non-paged pool" to grow massively, SQUEEZING almost every last bit of your RAM and also causes your pagefile to be VERY active. Which in turn affects your HDD/SDD IO performance.
The result = causing your system to be slowed down to a crawl, irresponsive
Temporary Solution
Restart the computer.
Alternative (Permanent) Solution
Open up "regedit" and go this key.
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\Ndu
Change the "Start" value to 4 (to disable it).
Thanks for reading.
Info:
Discussion Threads
Causes
Temporary Solution
Thanks for reading.
