first time stinktel customer here. keep receiving news sms from 1460 every morning.
how to disable this ah?
Make sure you disable the push sms in push settings of default sms app.
call stinktelfirst time stinktel customer here. keep receiving news sms from 1460 every morning.
After upgrade to 422, there is now voice navigation on the default maps app..... N it's quite accurate....
I'm not sure whether this function is there bef the upgrade, cos I only use the maps without turn on the gps n jus see the route... Without any voice navigation..
How is the Xperia Z's screen display under the sun? Can you still read the content?
Hope someone can help to answer. Thank you in advance.
Under the sun, need to up the screen brightness. Sure.
google map? this feature was enabled quite a while ago when they updated it..
Theres no more offline maps. I need it...
how do copy the text u type over the text box. last time on arc s i just press and hold i can select the range i wan to copy or cut
Z/ZL cannot do that? is there a new way of doing that?
End of day is how we cook our story to tell them existing customers also deserve the goodies.
I got 2 mths waiver for my recent renewal. Last year, I got a mth waiver for trying out MioTV for a mth. Previous years, I was always able to convince them for vouchers between $100 - $150 each time.
next time can go down with me and act as my father or not ?![]()
Just tell them they are losing a long time customer and that you are porting your number to M1 or Starhub if they don't have incentive for you to stay.
