I did tried that and it works pretty well...quite strong signals with the antenna against the wall...
Hi, Can share exactly where did you bought the balun transformer.
Matching transformer? Sim lim Tower...its not exactly the same as in the video. It does not have the 2 wires but will work nonetheless
I thought It had to been those 75-300 ohms type.
Btw, I had try to ask around over there but apparently most of the the shop personnel give me a blur look ...hahaha.
Any shop in particular and the cost of it. Thanks
i just bought one. later tonight i'll try DIY an antennapreviously many of them bought it at SLS level 3, UF technology~ they placed in a box on the floor~ that was few yrs back and it was selling at $1~! not sure it still selling or nt~
I used the same transformer and tried on both clips only and CD version. Both works for me.
compared to my amplified antenna, this has lower signal strength, but very high and constant signal quality. my amplified antenna gives fluctuating signal strength, but reaches 100%, same goes for signal quality. occasionally, it drops a lot and i see green pixels.
this DIY antenna gives very constant smooth picture. another thing i'd like to point out is the position and direction of the antenna does matter.
LG 42LM5800Signal Strength is far less important than Signal Quality. Since u get 100% for Signal Quality, that's very good already.
Btw what TV are u using that can tune to DVB-T?![]()
Oh izzit? not too sure if it my location issue Or my workmanship....? Haahaha...
Btw, any different between the 2 version?
Just get the cheapest rabbit ear antenna from the mama shop below the hdb blocks. Most will sell it around $2-3. Then salvage the balun transformer.
Better than making trips to sim lim I think.
