Is this setup for gaming okay?
eegnnna
Cpu & Mobo : Asrock H87 Performance Fatality +I5 4570 - Tradepac @$392
Corsair Vengeance Pro Series 16GB (2 x 8GB) DDR3 DRAM 1600MHz C9 Memory Kit (CMY16GX3M2A1600C9R) - mynextcom @ $184
HDD: W DIGITAL 1TB BLUE 64MB SATA3 - tradepac @ $80
SSD: Plextor M5S 128GB - tradepac @ $139
GPU :MSI GTX 770 TWINFROZR -mynextcom @ $645
PSU & Case: Sharkoon T28(RED) + Seasonic M12II Modular 620w 80+ psu- pcthemes @ $195
DVDRW Samsung 22 x DVDRW tradepac @ $20
Total : $1655. - Mix and match
Asrock H87 Performance (BUNDLE)
CPU BundleLGA 1150: Intel® Core™ i5-4570 BUNDLE
S$420
Sharkoon T28 Red
S$84
WD 3.5" 1TB SATA 6GB/s, 16MB Cache, 7200RPM (Caviar Blue)
S$88
MSI N770 TF 2GD5/OC (GeForce GTX 770 GAMING) (BUNDLE)
PSU Bundle Selection*: Thermaltake Smart SE 630W Modular
S$714
Samsung SH-224 24x DvD+-RW
S$24
Plextor M5S 128GB SSD Sata3
S$139
S$184
Total : $1653 , all these are from MyNeXTCom, so.. guys which one will you all recommend ? :O
royfrosty
S$420
Sharkoon T28 Red
S$84
S$88
S$714
S$24
S$139
S$184
Don't bother mix and match. It is not the price as it seems.
The price you see on the paper itself is consider a bundle buy. And their bundle buy means you are buying as a whole com from that particular shop.
Like the other day i went to Best buy and also Best price.
Both are charging different from the price list.
So ya, try not to mix and match. I rather you go to 1 store and settle everythng. Still possible to go for further discount paying cash.
Teng Zai
I don't really agree. Those shop just want to earn as much as they can from you. If you are resourceful, plan your trip right, and of course have golden tongue for bargaining, it is easy to get their so called 'bundle' discounts even when you don't buy it in 'bundle', for the simple fact that they don't sell at a loss.
So as long as you are able to convince them that you will not buy anything else and only that single item at bundle price, they will still sell you if they earn, and ofc ONLY if you do it right.
Simply start off by going there and tell them WHAT YOU NEED. If they come up with things like 'bundle for you?' Just tell them you already have an entire rig at home waiting for you to slot that graphics card in :o Ofcourse, still got more tricks and tactics.. ownself discover!
Ofc, won't work all the time. I'm not the best at bargaining and talking so there's always someone who can do better. No harm trying, since you already go to SLS, it might save you a couple of bucks that you can put in your rig, or the luxury of cabbing home :)
Worse come to worse, just buy the entire rig from the shop lor and say you fweels like buy another rig now since they tempt you. Ask them give you special price to 'tempt' you even more.
eegnnna
royfrosty and TengZai is exactly speaking why am I having a dilemma. Is thermaltake PSU okay? :o
Teng Zai
PSU shouldn't worry too much, most mainstream brands are pretty solid. If want more info, can see reviews lor.
Hunt for price/watt/value/efficiency certification.
Your choice on the bundle or not. If that few dollars you think not worth your effort or worth risking the time/effort, then just go for bundle. Can try bargain a bit also!
ragnarok95
Senior Moderator
Senior Moderator
Got time to spare just go ard and match and mix. No time just walk into shops like pctheme/CM and have them to do one set for u and open mouth for discount.
royfrosty
Thermaltake ok lah. So far never give me problem.
Thermaltake Smart SE 620W modular bought with a bundle for $90.
Basically what i like about this PSU is the flat cables being used. Extremely good for HTPC imo. But oh well i have moved on to ATX. But still it looks good and neater to manage the wires in my new sharkoon t28.
But the reviews people post till like damn jialut like that. Don't know why.
Anyway i might be looking for a red led psu soon. Once done i have a complete red set.
royfrosty
Actually i prefer to bargain from one shop haha. Easier for me as i bargain till no tomorrow.
Tradepac has managed to offer me my mobo and Cpu and chassis and Wireless N adapter all in for $550.
Price list add up is $575. They charge me $584 due to i did not buy in a full set.
So i bargained from $584 till $550. Still wanna bargain further till tradepac dont wanna do my business. Then finally just pay $550 lol.
I went to other shops all don't wanna budge. And their MSI Z87-G45 gaming + i5-4570 already almost $490
Bargain also can't bargain much.
betaunknown
I think that's not tradepac. You are referring to "best value" Pte ltd. :)
eegnnna
Sorry for reviving, and also thanks for all of your help and guidance.
How do I check how much speed the lanport supports to?
shadow84
Check your mobo specs, it will state whether it is 10/100 or 10/100/1000... the latter is desired..
ragnarok95
Senior Moderator
Senior Moderator
Currently almost all mobo lanport support 10/100/1000.
eegnnna
qcj3pcxvp
Hi, what's the difference between the highlighted rams? Cause there seem to be a significant difference in price but one with CL9 one without
Teng Zai
You got read finish that article bo?
The top i7 desktop Haswell isn’t worth buying a new mobo for.
As quoted from inside. This means if u upgrading from ivybridge, just upgrade your processor to a better 1155, instead of going haswell.
This doesn't mean that getting IB > HW from scratch or from builds before IB, such as clarkdale and older.
