Hi all,
Not sure if i asked this already. You guys have been recommending quite a few good shampoo. I think I will go hunt for Geovanni gold wheat or something, while waiting for junhong bro's stocks for kanebo to come. Just a question, after using these shampoo, do you all still go for hair treatment in salon? Hairstylists at Kobayashi recommended i go for one, cos i got oily scalp. But not sure if constant shampooing will solve the problem or we still need to go for treatment, which is not cheap?
On top of what other guys had mentioned, i feel that if you are unsure of whether to spend the $100+ on such packages a not. Perhaps you can try this first.
The primary purpose of treatment package is to unclog the pores in the hair which is already clogged. It might be mild or severe based on one's condition which i have no means of determining. Hairstylists have no way of determining with their bare eyes too and they only do so with the aid of machineries. These machineries that we see in salons are capable of analyzing the pores in your scalp with great details.
With this generated diagnosis, you can actually determine if you really want to continue with the package to rectify your current issues. To add on, it got to do with these clogged pores which prevent or hinder the growth of the hair of one. Sometimes, we do find ourselves having slow growth of hair at certain areas which is attributable to clogged pores. However, severity over here is wholly another issue to be noted.
Moving on, investing in a good shampoo helps to effect your improvement/current situation to a greater extent. Exercising good and proper hair care religiously and knowing what's important for your hair type is in fact essential for one to do so. So one ought to understand that shampoo helps to maintain and control the excess dirty oils/impurities in the hair, without allowing them to further clog the pores in the scalp. Whereas treatment is to unclog the pores in the scalp to allow better growth of hair for one. Hence, you can just request your salon to help you do a diagnosis of ur scalp first and you can decide thereafter.
