DVD & HDD Recorder.
Streetwise
A DVR is something like Starhub's Hubstation, right? I don't really want to pay monthly rental for a box that isn't mine... Are third-party DVRs available, or are they extinct too?
the big dept stores should hve DVD recorders.....seen NTUC, Courts, HN, etc.......
Uraku Asia
Hi all,
I'm thinking of buying a DVD recorder with hard disk to record TV shows, and to my horror, I find that they're getting phased out (or have already been phased out). Does anyone know where I can still find DVD recorders? Or do I have to resort to Amazon for units like this?
Thank you.
If you want to record your hubstation tv show, you may consider this Uraku S-200C HD DVR. It's support USB and HDD recording. Thanks.
Norman Chan
You can go to Funan - Harvey Norman at the basement , they still sell some Panasonic and LG dvd+HD recorder.
derrickgoh
DVR not just from starhub. Go to pc shops & look for the brand haupage (my spelling maybe off). It records to the box then u save on your pc or burn to disc.
Kiwi8
Deluxe Member
Thanks for your reply, but I'm looking for a simpler way because I'm not too tech savvy when it comes to TV.
Nowadays u can make the HTPC behave in a user-friendly fashion just like a TV, with freeware like XBMC.
leonaheidern
I also need something simple for my mum to use similar to Hubstation.
I need to get the Sesame Street shows off the Hubstation for my niece before I can go optimize the Hubstation hard disk
The Hubstation is a rental unit and working fine until the recent firmware upgrade making it slow to change channels and hard to record shows (it keeps saying its full but there are 15 hours left of recording time inside).
I used to have a ACRyan PVR72100 but it died a few years back (something burnt inside).
I got this for her but she finds it too hard to use.
Qoo10-Singapore - TV/Major Appliances - Smart TV DONGLE TV BOX QUAD CO...
Any idea what else we I can get her that is similar to the Hubstation interface and can record the shows?
lancer6238
I just bought the Panasonic DVD recorder from Harvey Norman. According to them, they also have the LG ones. Thanks to everyone for your suggestions!
Citiguy
lancer6238, may I know:
  • What is the model number?
  • How much you paid for it?
  • Which branch of Harvey Norman did you buy it from?
TIA. :)
lancer6238
TIA. :)
I bought the Panasonic DMR-EH59 for $479 (original price was $599). I contacted HN via their website and one of the retail managers brought a set over to the HN nearest my place.
Citiguy
lancer6238, many thanks for the information. :)
Did they give you a direct discount?
kun1he2
Problem is that it uses Composite input - which typically results in major quality loss.
Also, DVB-T2 coming real soon... is there a new model coming soon?
Btw, I'm also considering the NV-812 model which has component input (but non-digital tuners unfortunately) - how does the video input quality compare against the S-200C? Does component input give better image quality?
kun1he2
I believe it needs a PC to work? i.e. it does the video capture and encoding (or is the PC CPU doing the encoding too?) and the PC needs to write the video data into HDD.
Uraku Asia
Composite input is good enough for some basic user.
Yes, we have a new DVB-T2 STB model launch in end of this year. But it is not support AV input recording.
Not much different. This is because NV-812 Component input recording image quality maximum video resolution support up to 720x576i only.
kun1he2
I've tried recording videos off my hubstation hd into my panasonic dvd/hdd recorder via composite and the quality is bad.
I suspect most of the quality loss is due to video being transferred along one yellow cable, as opposed to separate video components, i.e. it is not just a simple matter of video resolution?
For my use case, which uraku product would you recommend?
okiknowu
Great to know that HDD + DVD recorders are still being sold..
One sales man at Courts told me obsolete already..
Citiguy
Yes, but with DVB-T2 standards to be implemented soon, is there a use for such recorders?
Uraku Asia
How about the signal quality if you direct view your Hubstation Tv program from your TV via Composite input?
The recorded signal good or bad via composite input, it also depend to the recorder main processor. Usually, the record video quality will be same like a DVD quality.
We will recommend S-200C HD DVR for you.
