should i improve my pc? just made
sophnet
hi all just got this made at fuwell.. mainly for gaming
should i upgrade anything to make it faster? like go dual graphic card? increase the ram to 32gb? or something of that sort
sorry im a tech noob here
here's the specs
- Asus Z87 Deluxe (haswell) 4770k 3.5
- Plextor M5 Pro 256GB
- WD Black 2TB 7200RPM
- Cosiar Dominator Platinum 2 x 8 GB 1600 CL9
- CM storm trooper black
- Asus GT780
- Season Xseries 1000 w
ragnarok95
Senior Moderator
Senior Moderator
In before people post u dun need a 4770K for gaming.
ragnarok95
Senior Moderator
Senior Moderator
It's fine. Just that people preferred 4670 max for gaming. Even if you have tons of cash for your rig. :D
It's a culture here la... :s13: :s13:
All 4 cores 8 threads will all kanna whack down to 4 cores 4 threads. :s13:
sophnet
thanks alot. i should have done some reading before purchasing.. i just stepped in and chose the parts mainly with the mentality thinking faster is better :(
Ark Law
here's the specs
- Asus Z87 Deluxe (haswell) 4770k 3.5 :vijayadmin:
- Asus GT780
- Season Xseries 1000w :vijayadmin:
It's okay, but just not getting the most value of what you spent. Unless you bargained/regular customer at Fuwell, you could've saved $50+++ in total if bought from other shop(s)
twasken
Always better to research on your own or ask the bros here before going down to hoot parts. Unless budget isn't a problem for you, then just go for the best of the best :s13:
sophnet
hi there $50 or $500+? they did give me a slight discount.. but i didnt ask for that discount.. as i mentioned before i'm a tech noob.. so whatever the salesman told me, i basically just nodded my head
sophnet
oh and roughly, with this current setup how long do u think it can last for in terms of gaming? meaning the lifespan before i have to upgrade again
Nostalgiaa
That build's a beast! Total damage? :eek:
here's the specs
- Asus GT780
shadow84
How much you paid for this setup?
I think it will last for at least 3+ years, before you can decide to upgrade.
Ark Law
$50, it can easily range further than $100 especially for high-end builds such as yours.
sophnet
mind would be considered high end build?
i always thought something like dual graphic card
32gb ram
512 ssd of this sort would be counted as more high end
wuweiz
No need to improve liaoz lah.. Unless you want more cooling for your rig...
Not here to comment if u wasted money or not.. lol..
sophnet
how should i go about more to make it more cooling? the desktop is also currently placed in an air conditioned room which is constantly on.... would that help?
Ark Law
hi there,
altogether it cost me 4kish with windows ultimate os 64bit installed
My rough calculations....
- Asus Z87 Deluxe (haswell) 4770k - $820
- Plextor M5 Pro 256GB - $289
- WD Black 2TB 7200RPM - $205
- Cosiar Dominator Platinum 2 x 8 GB 1600 CL9 - $245
- CM storm trooper black - $259
- Asus GT780 - $960
- Seasonic Xseries 1000w - $289
- Win7 Ultimate x64 - $110
- Assembly Charge - $10
Total: $3187. Got buy KB, mouse, monitor or other stuff?
Ark Law
Don't tell me you're running on the stock cooler? :s22:
