derrickgoh
- Jan 1, 2000
As mentioned before, the shape of the room is very important. Size as well I figure.
Take the pic below for e.g. The living room is very long. If you add the bedroom as well, its actually an inverted "L" shape.
I can imagine this is going to be havoc for the sound bar with the sound waves bouncing all over the place. Since the room is not an ideal shape, would it then be worth it to pay close to $4000 for a high end sound bar such as the Yamaha YSP5100 or should one just settle for a mid end sound bar costing less than half the price such as the Yamaha YSP2200? Or heck, even those lower end sound bars costing a 3 figure sum?
I appreciate the more expensive models may have better sound but again, the issue now is the odd shape of the room. If the shape is going to screw things up (for a lack of a better phrase), is it still worth it investing in a high end sound bar?
One solution I suppose is to close the sliding door outside the bedroom and perhaps install another sliding door beside the bomb shelter. That would help make the living room smaller and more squarish in shape.
However that may not be practically 'cos firstly I figure its not cheap installing a sliding door. Secondly, a 2 room flat is small enough as it is, the more stuff you add (even if its a mere sliding door), that is just going to make the space smaller.
