Building a gaming rig
Asrock B75m-dgs + i5-3470 ~ $297
Kingston Value Ram 8gb ~ $78
WD Blue 1tb ~ $78
Powercolor 7870 2gb myst ~ $290
Seasonic m12ll 620W PSU ~ $110
Xigmatek Asgard XP ~ $58
ODD ~ $22
changing this to geforce 780 for gfx is okay for gaming already?
battlefielder
WD Blue 1tb ~ $78
ODD ~ $22
I am not by any means a expert because i just came over to pc comm few years ago.
www(dot)imgur(dot)com/RiWr2Na(dot)png shows the benchmark for Battlefield 3 with 780 and some other cards like the 7970 and 7990. I got this from a website got Kotaku so i think it should be reliable.
All max settings and even higher settings than standard 1920x1080p. look for resolution at bot. of image.
royfrosty
WD Blue 1tb ~ $78
ODD ~ $22
Do you have any idea how much is a 780 cost?
Probably you wont know.
$950 around there. Just the card alone.
If you are confused. What i mentioned the Powercolor 7870 is an AMD card. Geforce gtx780 is an nvidia card. And this 2 cards are very different. Anf of cause a huge price gap.
battlefielder
Talking about the new cards, i forgot exactly how much those costs these days lol.. Better stick with 2012 cards =:p & average students like me wait for them to drop around late 2013 or 2014.
i see, anyone knows any website where they have a comparison of graphic cards in terms of performance,benchmarks etc.
so roy.. the rig u suggested i can anytime upgrade the graphic card for better performance am i right to say that? thank you for your replies and suggestions really appreciate it.
royfrosty
Yes no problem, you can upgrade the card in the long run. Probably last you a year and a half or 2. Depends on the gaming industries also.
Just google "7870 benchmark" can see quite a couple of sites.
royfrosty
When you go out to work you can start thinking of new cards already lol.
Now you student no money can understand. haha
royfrosty
so for this mobo
MSI Global ? Motherboard - P55-GD65
if i put in 7970 ati gfx i cant get the full performance since its only gen 2? this card is gen 3?
That mobo is an EOSL mobo (end of service life). From the looks of it their latest drivers support up to max 2011.
Yes you are right. You still can use the card. But not up to the cards capability.
hmmm.. in what way will i be able to get the full performance of the card then? what are the things to look out for the mobo specification?
nippp0n
CPU & Mobo: i5-3470 & Asrock B75M-DGS @ $292
Ram: Kingston 1600mhz value ram 8GB @ ~$80
ODD: Samsung DVD RW @ $22
HDD: Hitachi Deskstar 500GB @ $60
GPU: Gigabyte GTX 760 Windforce @ $400
GTX 760 should be able to handle most games at mid-high settings comfortably with reasonable FPS.
Case: Sharkoon T5 @ $68
PSU: Seasonic S12 520W @ ~$78
Total: $1000
Buy and build at Tradepac.
royfrosty
Total: $1000
You have no idea how much i spend on my rig already.
Anyway if you up to 1k
WD Blue 1tb ~ $78
ODD ~ $22
Total cost $933 Build at tradepac NO OS & SSD.
IF you up the budget by a bit more could get the Palit gtx760 2gb jetstream + Seasonic m12ll 620W PSU bundle ~ $458 by PC themes.
Which will land you a budget of $991
See even nipppon bro build is almost about the same.
So no point of you searching for EOL boards and trying to find the best pcie gen 3 support.
And boards + CPU must go hand in hand. What you search the P55 is based on LGA 1156.
shadow84
Why both mention same parts from same shop but with different prices??? lol...
