Viewing Distance Discussion Thread
sonic
I am using 50" plasma with viewing 1.5m to 1.8m.. depend on sitting postures.
u_ntitled
hi guys,
for about 3 to 3.5m, is 46" or 55" better? Must able to appreciate both SD and HD...
thanks
kelvinti
In my bed room and I have been watching a 32" LCD TV for 8 years until it went kaput 4 days ago.
My viewing is a striaght-line to my newly purchased 40" Full LED TV which is about 2.2m away and I'm fidning it very comfortable and enjoyable!
petetherock
Moderator
Moderator
An updated chart with 4k:
CarltonBale.com » Does 4K Resolution Matter?
artyboy
I intend to get a 60" 3D TV for my hall at viewing distance of around 2.9m. I checked the THX viewing distance calculator and it actually recommends 2.1m and maximum at 2.9m. Any bros here watching a 60" 3D TV in a 3-room flat at viewing distance of 2.9-3m? I will be mainly watching movies - Bluray/HD movies (1080p/720p) and the occasional 3D Bluray and DVDs. I don't expect SD content like TV programmes to look flawless on such a big screen but what about upscaled DVDs and 3D Blurays, especially on a passive 3D screen which has that visible horizontal lines syndrome. I have been watching a 42" HD-Ready (720p) screen at 2.9 m and want to know if a 60" 3D TV would be too big?
Prof. Utonium
Should i get a 50" if my viewing is 2m?
I'm curious about this too. Any inputs? Tried using the calculator but quite confused with the numbers and different systems e.g. THX. Just for normal viewing. Though I would end up moving myself and the sofa when it comes to watching HD and 5.1.
:s12:
petetherock
Moderator
Moderator
2m is not an issue if you only watch Full HD.
If you watch FTA channels, you need to see the chart for SD distances..
eyz
My viewing distance is 2.5m, and from the calculation of 1.5 or 0.668, the optimum size for my TV is 65 inch. Is there a upper and lower limit for the size?
Is the ratio 3 for the lower limit and ratio of 1.5 for the upper limit?
65 inch looks very intimidating!! and destructive to the pocket.
hehe
oohman
hehe
Is this also a 4 room Bto flat..
I am thinking of getting a 46 inch only. Shld it be enuff for watching TV programmes
jskc3617
Few year back I change from 37" TV to 46". Actually want a 55" but quite costly that time. My viewing distance is about 2.3m to 2.5m and 46" TV viewing look just ok but I feel 55" will be much better. I would recommend for those with 2.5m viewing distance if cannot afford to get 60"-65", at least get a 55".
ahbear82
Hi.. for viewing distance 1.9m to 2.5m, how many inch tv should i get, for Full HD and 4K.
sigurros
used to seat about 2 m from a 100" screen FHD. Initially felt big. But after a while, you will get used to it.
rockingdude
58" at 2m.. .watch both 720p movies, and cable channels, is it too big?
Thinking of either 55" or 58"...
warr
2 meters? for me, maximum is 47 inch.
if the tv fills over 30% of your vision, it is bad.
don't even think of 55 or 58. lol. remember, it is a tv, not a cinema screen.
