Google Nexus 7 2nd generation
bhkpop
how long you guys take to fully charge ur N7 2 from almost empty?
i realise mine take v long! maybe like 4 - 5 hours? cant rmb. shouldn't be this long right?
Are you using the cable from the box? Or just random micro usb?
If not mistaken, there is some posting mentioning about this slowness. You have to back track though hahaha
deepblue_82
u have to check of ur amp... 1,1.5 or 2?
less power longer time..
more power shorter time
Cryogenist
The given charger is rated at 1.3A.
Given the general efficiency of most charger, which is around 70%.
The resulting ampere is around 0.91A
So at 3950mah, you need almost 4h to fully charge from 0% to 100%
This is a rough calculation.
Rickosw
Hi
thanks for the reply, for the brothers that wack from Amazon, what are the chargers that you guys are using?
Any particular brands that you will recommend? price?
cheers!~
crissxx
Has anyone bought a keyboard case that is confirm compatible with Nexus 7 2nd gen? Found some on eBay but scared they might not work :/
perry
Took the plunge. Paid S$310 for a BNIB Nexus 7 16GB Wifi from one of the sellers in VRZone. Not bad I guess. No need to wait 2 weeks for it to arrive. :)
Two weeks!!!
Got mine in 5 days direct free shipping from Amazon through UPS.:s12:
fantasyrulz
LOL i bought the screen protector put myself and i got so angry i crush it and threw it away DMN
can any 1 help me put it on :(
swordy84
Anyone's shipment is by i-parcel?
Mine is stuck for almost 3 days with the same status "In transit: Delayed", customs clearance delay. Think it gonna take at least 2 weeks to reach here :(
