kimurastanley
- Sep 21, 2009
Mine delivered by iparcel. Stuck for few days but it suddenly was delivered to me yesterday. Great
anyone using your nexus bare without screen protector?
check with expert here, if i were to get this tablet from amazon.
can the AC Adapter & Power Plug be use in sg? TIA.
It comes with the US 2 pins plugs; so you need a travel adapter for local use.
thx for the reply, anyway something like this will do rite?
Amazon.com : Universal Plug Adapter for USA. 3 pin Grounded plug. Converts Foreign Plugs to American Grounded Plug Adapter : Electronics
Yup. Those kind.
Can find it most hardware or DIY shops for very cheap price. IRC, is around $2.
Amazon is cheapest but need to wait. I need to get it before 11th. Which place in Singapore sells the cheapest? THE OPENSURFACE is selling for $360. Thank you all.
Wah sian anyone experiencing random reboots? I last time on stock got now on CM10.2 also got![]()
I did, i realised it was the chrome beta app, reinstalled it and the problem went away![]()
