Port number.
enter ur dsm using port no. 5000, as ur webstation is on port 80 is used for it.
Port number.
Best joke of the day.
Synology naming rules, first set of numbers represent the max number of bays, the second set is the year it's launched.
It's a 2012 model but was launched back in end 2011.
Through this experience you can know that Ace Promoters are more of a hit and run type...didn't realize 10 years ago got USB 3.0
The D-Link uses the standard linux raid manager (mdadm) for its RAID. The last time round, i manually rebuilt the RAID5 setup for data extraction (DNS-343 failed back then). I did not try for other RAID levels like 0 and 1 though.
I have install audio and photo station, How can I bring them into my control panel?
The folders for audio, video and photo scanning are set thru the media indexing service found on the last row of the control panel...
Was thinking of getting My Book Duo Live but after reading this thread feel like getting ds213j with 2 x 3TB WD Red instead ;p
Problem is I'll have to get down with some manual installation & formatting work with synology.
I have a mixture of Win & OSX at home.
Which file system should I use to format the hdd?
Kena poisoned by a fellow hwz Synology user.
Went down COMEX and bought the DS213J just now
Setup was a breeze.
Uploaded a few videos and tested the DS video app on my iphone.
First time NAS user.
Pretty pleasant experience so far.
When I access with my apps from android. It says "Connection failed. Please login and try again". I don't know what is wrong.
Connect over wifi
Did u auto detect the DS?
Login as admin?
Still the same.
Still the same.
I assumed u have already installed the program on your nas as well?
Sorry, i am new user here.
Blind leading the blind. Haha
