you apply mousse, blow dry. Must blow FULLY dry and rake your hair backwards or side for the shape while blow drying.
depending on what pomade you using, take a little, too much will be too wet and it's hard to dry.
spread the product evenly on your palms, go thru your hair back or sidewards using the product in your fingers (not palms yet) then, using palms to rub on your head, spreading the product.
then rake your hair into the shape you want and that's it.
its done.
i literally copy this video! same product use. even for the spray
