[NAS] Synology NAS owner club!
Norman Chan
For Synology NAS , is it die-die need to use either WD RED NAS hard disk or Seagate NAS hard disk ? What will happen if you put in a normal 7200 rpm desktop hard disk ?
Twilight
No it's not a die die must get red.. To me red harddisk don't seems to get good review as u keep hearing red die.. I am using hitachi 7200 3tb harddisk
kakaBoBo
for harddisk i alway try to get different brand or batch.
if not suay suay got problem all ganna.
raid 5
ducky_88
Anybody know what is the conversion progress in file station converting? It seems like taking forever to convert.. Anyway to disable it? Thanks.
Dexter71
Guys
Have anyone enable Xunlei Lixian and got it working? I kept getting the message that I am not logged in into xunlei but at the download station settings I have already done so.
Many Thanks for sharing. : >
Egoistee
I checked liao... When i log in using my wife id.. still can see the folder.
But cannot proceed further though.
Egoistee
I dont want it to show up in the Network Place for those without access.
If it's totally hidden, how do i access to the folder/files?
ducky_88
Anybody know what is the conversion progress in file station converting? It seems like taking forever to convert.. Anyway to disable it? Many thanks.
Egoistee
Nope disabled.
Nv i will just leave it until later.
Now still ok.. scared next time my unborn kid will get curious..
So that's years later so let it be now :p
Btw, what is the usage for WebDAV??
I tried access my NAS using my iphone @ home using the DS file app.. and it says i nv set my WebDAV...
What does it do actually?
zennith
Just disable it from showing up in your network places, you could do it on your share folder option.
how to access, then you need to key in the full address yourself.
example: \\10.10.10.10\adultx :D [although "adultx" didnt appears in your network places, but manual path will bring you there, with your ID and password then you could get access on the folder. :s13:
