eh..noob question..but.....
Hinata76
how to use own ringtones/music for xperia Z alarm?
dun seems to have a option to choose ur own music?
:o
pic added.. for ALARM not for ringtone.
Rashkae
:o
You can install ES file explorer, then when you want to pick a ringtone use ES file explorer to select instead of "Sound Picker".
Or put it in the internal memory in the "Media" or "Ringtones" folders.
Asphodeli
Open Advanced Settings -> Alarm Style -> Swipe all the way to the right -> Add new Style
Hinata76
oh!! thanks!!
wow....seems samsung one easier to config alarm ringtones..
well gotta get used to it..
Jumpman23
:o
Just create a folder called "Alarms" in the root directory and transfer your own alarm tone there.
Asphodeli
oh!! thanks!!
This is Sony's style...Samsung has its own style...most people are posting the standard Android Alarm style, that's why the instructions are confusing ;)
shadey
Or just put it in the internal memory in the "Media" or "Ringtones" folders
Ralphel
actually it works teh same way for alarm or ringtone
juz click teh music icon at teh alarm sound selection
Sambuca78
I also have a noob question leh about the GPS and aGPS.
Previously in Arc S, I can still can turn On "Google Location Service", Off "GPS Satellites" and still able to retrieve my current location.
But now in JB, Off "GPS Satellites" will also OFF "Google Location Service" and therefore unable to use Wifi or Mobile networks to determine my current location.
Did I miss anything??? Thanks!
rssd21
To use ringtones for your alarm, make sure it can be found in your walkman app.
When you are at the sound picker page, there is a melody icon on top right.
Click it and you will be able to choose from list of music that can also be found in walkman app.
rssd21
Settings/Accounts/Google/Location settings
Ok? :D
rssd21
Cannot leh, I tried that too.
The GPS will only work when "GPS Satellites" is checked.
Wifi and Mobile network cannot work leh... :(
Did you install google play services?
There is this "Google's location service" needed to be checked, found under settings/location.
You should be able to use wifi for location if you fulfill above 2 requirements.
