[NAS] Synology NAS owner club!
Hey guys, I just gotten a ds213j with a 3TB WD red but I am
experiencing some issues now...
1) Cannot access the NAS from the Internet (outside of home network) - My router is Asus RT- AC66U and I have done port forwarding for the router, with ports such as 5000, 5005 and 5006 opened. However, I still cannot connect to the NAS with the IP address. Upon using the open port check tool, it says connection timeout.
2) After I have done port forwarding yesterday, today the synology assistant and replicator is unable to detect the ds213j. However, I am able to access it using the IP address. Why is this so!
Please kindly advise!
ducky_88
1. If your ISP is starhub, You need to port forward to some other numbers not used in NAS configuration. I'm using port 82, and to remote access you need to create a DDNS account follow by setting up the configuration in DSM.
2. This I'm not sure as I don't use synology assistant & replicator. I usually key in my IP:5000
Hope this helps.
Egoistee
1. no
2. depends on how you define safe.
3. yes, if you configured it as it is.
My definition of safe in this case would be "No one else can access my NAS from outside... and have access to my files"
My NAS is now holding a lot of important contents.. like my CC, documents etc..
Gribber
Once you go online, nothing is safe.
Hope this helps.
Hi ducky thanks for the help!
1) Hmm my ISP is MR...I have set up the DDNS account but if I cannot access it via the IP address then even if I set up I also do not have remote access, right?
2) I see, alright hope others can help
Gribber
1. That is correct.
2. Check your router settings
zer0ne
Did you apply for MR static IP? Else no way your DDNS going to work.
ducky_88
Any people know how I can create a folder such that it can be synchronize with cloud station folder?
As u can see folders with the cloud on it. Trying to create one.
akiden
Using Download Station mobile on iphone within LAN, the BT search function doesn't throw up any search results at all. But BT search works well on Download Station in Mac.
Is this the same experience for all?
xJeris
you got do port forwarding bo?
tazzycorner
Good News for iphone users!
New update of the DS Video app supports VLC Player.
Now can stream & play rmvb and avi thru VLC.
