deaththeorist
- Apr 28, 2011
Ikr! Monster product. Dunno why discontinue
Chiobus are your main concern lar. I've heard abit about you.
very good what!Morning to all bros here!
Here's my first attempt! I know it look weird a bit.
Quicksand blowdry >seasalt blow dry again > gold digger >pp hair spray
But during the styling process with gold digger . My hair very dry. When styling feel quite pain as my hand pulling my hair like that. Cos my hair bleached blue before.
Any idea how to style it smoother?
I'm really amazed with quick sand and sea salt combo then gold digger to style it!
http://img853.imageshack.us/img853/5944/40cz.jpg[/I
I'm really amazed with quick sand and sea salt combo then gold digger to style it![/QUOTE]
Haha your hair looks ok. Told you gold digger is strong stuff. Haha very strong haha. It's normal to yank out some hair but there's a work around. Use lesser gold digger. Use bit by bit cause it dries up really fast on your palms. When it dries, really like glue. And don't go pull your hair like what slikhaar ppl do. Their hair texture different. Softer also.
And sea salt spray + quicksand is supposed to be rough and dry. Makes styling easier for us. Haha I don't know how to explain this rational in words but this is how it works haha.
If u want, can add 1 to 2 drops of water when you emusify the gold digger in your palms to prolong the working time.
Sss. I advice against blowing after quicksandThanks for the advice! Actually right now it yank out more and it drop liao.. Maybe I didn't use enough hairspray or wax.. ( "bu se de" to use finish.. Keke :x)
If not I'm going to perm or cut my hair..
After spraying. I use hair dryer blow with high heat to harden the finishing spray tho.
Anyway, was thinking to use use the curling brush to air blow my hair curl before styling.
Do I curl it after quicksand or SSS?
wow..ur M shape hairline is developing soon..
very good what!
very dry? hmm? thats how quicksand is supposed to work ar. i suggest u put sss first then quicksand second.
actually, rather than just dry, quicksand should make ur hair feel rougher.
i feel like taking microscope pictures of hair with and without quicksand to test hypothesis sia >.< anybody here wanna see?
On side note, anybody updated the IOS 7 ?
My ball shape hair but still incomplete yet. The middle part still haven't grow enough according to Su so she still can't cut a semi shape in the middle thus keeping the front and when it grows enough then cut away the front.
2 pumps of Seasalt, blowdry, Nigelle Bold Make Clay then Osis+.
[IG]http://i989.photobucket.com/albums/af11/x3dnd3x/IMG_8846_zpsf9a493d7.jpg[/IMG]
[IG]http://i989.photobucket.com/albums/af11/x3dnd3x/IMG_8847_zps5bbfcc12.jpg[/IMG]
