China Tablets to recommend
happily1986
I dont attempt to root it anymore since I think it caused my unit to overheat once before. Before I used exynos abuse not sure if it would still work on JB firmware.
Maybe you can also try framaroot from xda developers its possible it may work since this is samsung chip.
Thanks will try this framaroot. Exynos abuse don't work as the Exynos exploit it relies on I think is no Odin, has been patched.
yoman8
RaiderXXX
Anyone sent the tablet back to China for repair?
I bought my Yuandao Mini One 2 months ago and dead few days back.
I transfer movies file from my PC to the tablet and halfway transferring, the screen just black off.
Reset the button cant get it alive.
Try to connect to PC using method of pressing - volume button and power start button then usb cable also wont work.
launm88
bros i found this teclast 7.9 tablet slimer than ipad mini and charge via micro usb slot.
its using allwinner processor tho, how u guys think of this?
http://detail.tmall.com/item.htm?sp...=140105335569ed55e27b&pm_id=&initiative_new=1
edit:
and the newer ver with intel atom
there is another with rk3188
blue00
ard $30 to send back , can yr tablet be charge?
blue00
Plug in charger, cant see the battery icon charging....not sure whether is battery dead or screen dead or other issues.
check 2 things first
first u charge tablet for 1 hour
1. check wall adapter got hot?
2. check tablet got hot?
enrell69
5V 2A USB Charging Charge Power Lead Cable For Yuandao N70 N80RK TABLET | eBay
sg got?
enrell69
I have a lot of this cable. Tested working on my A31 tablet which can be power by 5V 2A yoobao powerbank. Also tested working on Pipo M series (those 9" and above) of tablet using RK3188
wanna sell one to me?
GloveK8
Hey guys, is the yuandao mini or pipo u8 better? I know that the mini have got wifi and battery issues rite? how about the u8?
Huston
u8 speaker is located at the front. Battery is 4700 can last longer than mini one. But slighly heavier than mini one. For mic tablet, their wifi is literally the same. Also depends on your wireless router. Within same area or 1 wall, signal is alright. Don’t really received well beyond 2~3 walls of barrier. But you can always boost up your wireless router. For U8 it accepts 5G n 2.4G.
