Do put the Jaybird Freedom JF3 into consideration also. Personally find the fitting better than the Jabra and Backbeat Go.Anyone can recommend me a sports earpiece? Budget around $150-$200. I would personally prefer a wireless one with a good fit. Was pondering between backbeat go 2 & jabra sports on the website.
Thanks!!
You can consider the Beyerdynamic Custom One Pro. Should suits you quite well with the sound slider closed. There is a walk-in price for it so you can dropby and give it a try first.Fellow bros.. pls do help me out..
- Your rig : iPod classic 7th gen
- What type of usage : music
- File format used in your source : mp3
- Genre of music you listen to :90% heavy metal. all kinds of metal.
- Headphone / earphone type :headphones, closed preferably since i used it mostly for commuting
- Other requirements (if any) : none
- Budget (in figures) : 200-250
Hi there,
You can give the Fischer Audio Consonance and the Audio Technica CKS55X a try. Both are strong in bass.![]()
Last week I went to your Plaza Sing outlet for a Black Audio Technica CKS55X. Unfortunately, there are only two white left at the rack. I asked a young sales guy who approach me and he told me left with these two white and didn't even offer to check for me if there is any stock at ION outlet....
At the end I bought the black CKS55X from Best Denki instead.![]()
You can consider the Beyerdynamic Custom One Pro. Should suits you quite well with the sound slider closed. There is a walk-in price for it so you can dropby and give it a try first.![]()
Thanks for the recommendation. Did some reading online and there's quite alot of good reviews. Was wondering if u sell the accessories like the cups, cables etc as well.
hi guyz,
im looking for a headphone for pc/general use.
i don mind a bulky headphone since i will be using it indoor most of the time but
i need it to be comfortable for spectacle users/ and long period of usage.
- Your rig (Computer/MP3 Player)
- What type of usage (Gaming/Music)
- Headphone (mic is not necessary)
- Budget Ard $200
Help would be appreciated.![]()
Any Other Suggestions Other than Beyerdynamic Custom One Pro?
i recommend ATH-MK500. Go try it out at stereo. Quite good for its price.
Would greatly appreciate help ^^ thanks!
- Your rig: PC
- What type of usage: competitive gaming/music
- Genre of music you listen to: classical, vocals
- Headphone type: closed, over ears preferably
- Other requirements (if any) (mic, volume control, 5.1ch, 7.1ch etc) mic optional, priority is quality of sound. doesnt need noise cancelling
- Budget (in figures) ~200, willing to stretch budget if theres a significant improvement in quality
Check out the M-Audio Q40s.
Do note that I recommend to swap the pads to either a Beyer Pad or HM5 pad as this will greatly increase the comfort. I used the HM5 pads with rope spacer.
And if you are going to use it as a portable (like me) try to change the cable to something like the vmoda cable.
Cheers!
you can try out the JVC HA FXZ200, it is a little power hungry though. Ur phone's battery will take a batteringAppreciate your advice in advance!
- Your rig: iPhone
- What type of usage: Music
- File format used in your source: Mp3
- Genre of music you listen to: Mainly house/trance and R&B
- Earphone type: IEM
- Other requirements: Slightly prefer straight-down over over-the-ear style of wearing
- Budget: Approx $500
