Another DIY
sakratulmauts
I have build last year a DIY PC -------->
But today i wanna build another one for my parents home
Please advice me on my budget on $1000-$1400
More to movie playback online stream youtube to 42inch tv
AMD A10-6800k FM2
Corsair H60 hydro cooling
Hptc case
sakratulmauts
AMD A10-6800k FM2
Hptc case
i forget also need sound card .......
royfrosty
Dont need sound card. Just use onboard. Unless you tell me your parents got golden ears.
And fyi $1.4k to watch movies and stream HD movies is already an overkill budget.
Do you know that a Celeron or Pentium can do just that?
MSI B85M E33 + Intel Pentium G3220 ~ $180
Kingston Value Ram 4gb ~ $45
WD Blue 1tb ~ $81
HEC 300w True Power ~ $35
Xigmatek Asgard XP ~ $58
Samsung ODD ~ $21
Windows 7 OEM Home Premium ~ $115
Total $535 buy from tradepac. DIY.
wuweiz
WD Blue 1tb ~ $81
Samsung ODD ~ $21
Asus got one b81 or h81 (forgot. Lol) board much cheaper n enough for TS use le. Check tradepac pricelist.
sakratulmauts
WD Blue 1tb ~ $81
Samsung ODD ~ $21
I do not wish to have cpu in my system
Thanks bro
royfrosty
WD Blue 1tb ~ $81
Samsung ODD ~ $21
Thanks bro
Then what cpu do you intending to run?
shadow84
Or he meant that he alrdy gt the AMD A10-6800K FM2? And just need the rest?
royfrosty
Seems complicated. Not sure what he has and what he wanted lol.
sakratulmauts
Jus wait for him to come back online and say it properly lor.... found it funny he wants a h60 for htpc...
Apologised to all I kept typing error due to using my hp
ok like I say early
I want AMD system
Set up more to Media playback for movie hd playback
i have tv of 42inch intended to have a pc to replaced dvd player separate sound system
I just want a PC of whatever you all may introduced me regardless of $1000 more or less
In my system I want An amd cpu not intel You may say I not in favour of intel
I want a HTPC casing as not show people this is a pc.
a sound card I say for good sound system Asus Xonar ? Creative Soundblater Xfi?
Ram 16gb ? actually I prefer max out to 24gb or 32gb but I know it a waste but since my budget more I can add more
H60 ? no good ? ok how about H80 ?
I know this set are more to gaming system set up
if you think is is crap
i close this tread.
royfrosty
ok like I say early
I want AMD system
i close this tread.
1st thing 1st. If you have up to 1k you are way better off with an intel rig. The current a10 6800k is just on par with an i3.
2nd. A htpc dont require an onboard sound card. If you use a good amplifier or home theatre at home, using a hdmi or coaxial cable, you bypass the sound to the amplifier to do the work.
3. 16gb of ram is retarded if you aint doing photoshop, or any rendering stuffs. A good 8gb is way way sufficient and still have lots of access to be spared.
4. If you are looking up for a gaming setup with $1k you could land youself with a way much better intel rig.
5. We are here to recommend and guide you the correct way rather than steering you off to some other nonsensical or no logic path.
6. It is not crap. It is more important that you read up the current apu a10 6800k first rather than saying you wanna build an a10 6800k first. It is different from those fx series chip.
7. Be it a h60 or a h80. If you aint overclocking you dont need that.
8. Lastly if you are looking for a htpc cassing that is to make it dont look like a pc, then it is more likely you will go into an itx setup. Next is if an itx setup is use you also would not be able to add a sound card due to lack of pcie x1 slot.
Jian19
I think just recommend him a amd system will do :o
A10-6800k + Asrock fm2a75m itx ~ $308
Pc3 2133 G.Skill Ripjaws 2x4 kit (8gb) ~ $123
Plextor m5p 128gb ~ $149
Wd blue 1tb ~ $81
Samsung drive (optional) ~ $21
Fsp raider silver 450w ~ $68
Lian li PC-Q18B ~ $170
Total $920 ~
Say if u wan to add a sound card...
Asus Xonar DG ~ $79
Total $999
coyote
People want 32G. Just add $369 for another 24G mah.:s13:
Wd blue 1tb ~ $81
Total $920 ~
Asus Xonar DG ~ $79
Total $999
Jian19
Unless u running it as server if not why u need 32gb ram ? :s22: even 16 is overkill..
royfrosty
I add in the fun.
The expensive APU ever.
MSI A85XA G65 + A10 6800k ~ $353
Gskills Ripjaws 2x8gb 2133mhz kit x2 ~ $430
WD Black 1tb ~ $110
Plextor M5P 128gb ~ $149
MSI GTX780 Twin Frozr 3gb + Seasonic M12ii 750W ~ $1018
Corsair H60 + Corsair 300R ~ $188
Creative Xfi surround sound 5.1 PRO ~ $89
Asus ODD ~ $24
Total $2361 Buy at Tradepac. DIY
Board and APU promo is at Cybermind or PC themes.
shadow84
I add in the fun.
WD Black 1tb ~ $110
Asus ODD ~ $24
That is a gaming rig le... not htpc... lol..
It's like buying a ferrari to drive to your neighbourhood market for groceries shopping every weekend...
sakratulmauts
Wd blue 1tb ~ $81
Total $920 ~
Asus Xonar DG ~ $79
Total $999
Thanks a lot bro getting this tomorrow
sakratulmauts
I add in the fun.
WD Black 1tb ~ $110
Asus ODD ~ $24
This is wow n thanks bro
