bro,thats the risk of MIC tablets,it's always the battery issue. I have got 4 mic tablets before..all with battery issue..for long term usage i recon you stay away from mic tablet..now i paid a little more and are using ipad,at least no worry.
but the end point suitable for mic tablets?USB charging cable have. Sim lim sq, tower. In fact Everytime there is a computer fair, u can find it sold at all those accessories store.
as long it 2.5mm connector tip able to insert work. cos S$1 to S$2 at sim lim sq or tower but the end point suitable for mic tablets?
Tried liao both not hot at all.
Guess shd be battery dead liao.
actually at those prices to buy from overseas, isnt it better to pick up say a tablet at $200-300 locally?
my friend just bought a 7" huawei mediapad 3G+wifi for her kid from Fairprice Xtra AMK at $200+ and it looks good and seems fast and responsive. can use CC to pay and got discounts some more haha
wanna sell one to me?
Hey guys, is the yuandao mini or pipo u8 better? I know that the mini have got wifi and battery issues rite? how about the u8?
Anyone sent the tablet back to China for repair?
I bought my Yuandao Mini One 2 months ago and dead few days back.
I transfer movies file from my PC to the tablet and halfway transferring, the screen just black off.
Reset the button cant get it alive.
Try to connect to PC using method of pressing - volume button and power start button then usb cable also wont work.
Yes, I send my N90FHD back to Yuandao 12 weeks ago and it never arrived there - was lost by ChinaPost. Singpost will compensate with app $60,--!
Also note that Yuandao only returns to local Chinese address, so you need to use VPost or similar.
For your MiniOne try to press Power for 30 sec or so and with USB connected see if there is any sign of life when you switch on again, this helped me several times ...
I think the M7 is a better choice as it has full HD..looking to buy the Pipo M9 Pro with 3 G from
http://detail.tmall.com/item.htm?sp...ipo+m9+3g&rn=66b6f45706dcbd09edbf18b297361b87
anyone here using it? reviews?
The reason people buy mic tablets is becos for the price they r paying, those standard tablets don't cum with the specs they want..ie quad core, 2gig, fhd etc etcactually at those prices to buy from overseas, isnt it better to pick up say a tablet at $200-300 locally?
are there any fhd mic 8 inches tablets?
or are they waiting for apple to launch 1st before they improvise![]()
