iMac late 2013 released.
PetPet
Moderator
Moderator
Faster processors.
802.11 ac
PCIe Flash storage and many more
Check the Apple Store for more info!
iCubes
Bloody hell. I just bought not long only. Now the specs are so good. APPLE!!!!.
frizee
Great! Been waiting for this! :)
But, is SG Store updated too?
Cuz it seems like the shipping time is different from that of USA's, so I'm thinking if SG Store's been updated.
Correct me if I'm wrong.
LeonaV
Apple Updates iMac with Haswell and Faster PCIe Flash Storage - Mac Rumors
Not just that, they are also offering 256Gb, 512Gb, 1Tb flash storage upgrade options. Previously it was a single 768Gb flash storage optional upgrade.
Edit: Yes, Apple store SG is updated. To verify, look at the tech specs and scroll down to wireless. It's listed as 802.11ac now.
When you customise your iMac for the 27", look at the graphics card. It has now double GPU RAM from 2G to 4G.
cquey
i think its cheaper full specs, compared to the previous gen!
kero89
Hopefully the AC adapter is 3x3.
The 2013 Airs are using 2x2 though, hopefully Apple continues the tradition of selecting 3x3 adapter for iMac and the upcoming MBPs.
evershineoptical
I got the following specs :
3.5GHz Quad-core Intel Core i7, Turbo Boost up to 3.9GHz
32GB 1600MHz DDR3 SDRAM - 4X8GB
3TB Fusion Drive
NVIDIA GeForce GTX 780M 4GB GDDR5
$4306. you guys think it's worth it ?
should i get time capsule? 512 or 1TB SSD hard flash drive ?
it will be more than 5k !! is it worth to spend that kind of money or should I spend that on a windows machine. :s22:
LeonaV
3TB Fusion Drive
i7 is overkill, you don't really need it unless you do a lot of handbrakes or hyperthreading. Frankly, the difference is very minimal.
Don't upgrade the RAM from Apple store. The 27" comes with a panel that users can open and insert RAM in. Just buy compatible RAM and slot it in. It's way cheaper.
LeonaV
My iMac has no external AC adaptor. It's just a normal power cord.
carfan
Good advice!
Ultravox
3TB Fusion Drive
Go for 3rd party rams and save $840.
Get educational price if possible to pay for the ram.
