SAMSUNG GALAXY Note 3 Experience Sharing
ronnlim
You must use 3rd party launcher, I find it too big too, but I bought Nova launcher, I believe the Icon size must be purchased version too.
Dude thks man oh is it got to use third party? Anyone? Oh yah i tried lnstall knox .not so sure in both knix or normak mode any difference lol...look chim
Apparatus
But still, i dont think battery level will drop while charging with supplied charger and cable with all these functions turned on.
Perhaps charger or cable spoil?
Off the phone when charging lah. BTW did you charge your phone for at least 8 hrs the first time?
hwsinn
i almost fainted when i saw the settings screen. So many features which i dunno to on or off. So many services running in the BG as well
Nychlus
Err.. Just got mine last nite.. Fruit4ass transformer.. I have some really noob questions hence pls bear with me can?
- How come my Network only show 4G and not LTE? (Singtel value plan leh)
- I can use my powerbank (previously used on Fruit4ass) but using half of the other dock instead of the usual 3.0 USB rite?
- The pre-launch was selling Sandisk Ultra. Other brands 64MB with slower speed also can rite?
Jhyun
Charging for at least 8hrs the first time on lipo batteries is a myth.
1) 4G is LTE
2) The right half of the dock will fit a micro usb
3) Any speed will do. Consider getting higher speeds only if you plan to transfer big files. Small chunks of files make no difference since the rated speed on mem cards are for sequential transfers only.
chester121
Bro 4G and LTE is the same but different manufacturer wanna label it either way.
Yes you can charge the Note 3 with a microusb 2.0 cable as well.
Yes although using a slower memory card may reduce your performance in loading files from it.
05128959
What is the normal RAM usage like...
mine was like 1.3gb used... 1.2gb available....
so much usage?
zXioNGz
Did everything possible... update my mobo latest BIOS and drivers etc, factory reset my Note 3, charging via USB 3.0 is still very slow, battery level dropping while charging + using... sad :(
continuum
That's Samsung's trademark. It took me half a day to turn off features that don't like. But to be fair, there are many features which are very useful especially for people with disability.
FuzzyLop
USB 3.0 max current is 0.9k mah. Your wall charger is 2.0kmah(ipad charger current). So it charges at less than 1/2 the speed of the wall charger. Most of the older wall charger outputs at 1.0kmah(iphone charger current). And usb2.0 charges at 0.5kmah. You also may not get max speed as your computer USB ports may be sharing the current with other device etc especially when using usb hub. Best to get a powered USB hub to ensure full current when connected using the computer.
The galaxy charging current app is able to show input current to your samsung phone https://play.google.com/store/apps/details?id=com.abmantis.galaxychargingcurrent.free&hl=en
D3CA55
something i noticed about the Note 3 vs my Note 2.
tried to bluetooth paired the Note 3 to my car's Kutafec Fiscon, but it can't be done.
previously my Note 2 can pair easily. :(
FuzzyLop
do you all keep GPS on?
GPS on but no app using GPS means no battery being sucked. Only when app using GPS i.e. facebook will the battery level drop. GPS not like wifi. when you on wifi even if not connected to network will suck battery. GPS will only suck when its being used.
zXioNGz
Yeah I know about the current thing, but the problem you see, I believe it's the bad optimisation between Android 4.3 or Snapdragon S800 eating too much battery while using.
I charged my Note 2 via USB 2.0 cable, it's going up
I charged my Note 3 via USB 3.0 cable, it's going down, slowly
Given the battery capacity difference by only a little, the only way I think it's the Snap S800 eating too much battery, as well as the 1080p screen.
I hate it when I can't charge my Phone via USB desktop, even with USB 3.0...
