GALAXY NOTE III ACCESSORIES
human_shieldz
don't ask which shop
All in USD ah?
zXioNGz
wanna show us? might generate interest and becomes a extra $$
Nothing much, I just cut from my remaining skins from my S4, bought at Bestskinsever, and stick it around the corner and Samsung logo.
Anyway, good news from Bestskinsever, they are making skins for Note 3, but no release date currentlt
adix_82
Anyone order spigen stuff from amazon? Worth it? Need to go through comgateway?
Have to wait a bit.
U can try
Gadget world.
Far East plaza.
Mac friends at rocher center.
If u wan postage,
Go search for flushx on using the search option in hwz.
mzabu25
no choice bro.
i plan to get 4 extra batteries.
The original battery cost about $58(with out the charging kit).TOO EXPENSIVE sob.
Original battery got built-in NFC antenna, compatible one may not have that and end up your NFC will not work.
drevey
Short review for tempered glass and original s view cover. It closes perfectly without the case opening up after a few use. Jus installed about 15mins ago for the casing. For 3rd party s view cases, i think there must be 2 contact points on the case to activate the functions as i notice the original have it.
kyleongwl
Bro the one you have is a battery door replacement and not a snap on cover right? Which Gadgetworld branch did you buy it from? Any other colours? Tks! :D
I got frm the Jurong Point Outlet..Got the SP as well.
Not sure what U meant...But remove the original back and snap this on
derrickgoh
Just got back from p2o Mobile at Bencoolen. The last Samsung flip wallet is gone. I took it. :s13: There were still Samsung S-View flip covers there in various colours.
SGP oleo & matt still have tons of stock. Crystal sold out. SGP GLAStR I think only 1 left when I left.
