Xiaomi Box Android TV Box
_dXter
Got a xiaomi box, works great with the starhub free cable but not at all with singtel adsl line.
rerear
can comment what you meant by not working with singtel adsl? meaning very lag?
_dXter
Not possible at all. Anyway bought mine when was in china.
d3vilstarz
Does it have TVB ?? or what other channel , can it be stream in singapore as a lot of china streaming video is block
_dXter
It does not have channels per se. Just categories ie. movies, drama series, documentaries, etc. There're the lastest TVB shows in mandarin. Currently watching Triumph in the Skies II.
leong92232
The streaming depends on which apps you used. If rabbit is slow, try others. For drama I tend to use PP stream and Funshion. For TV live I forget the apps name. Some apps super slow but not every apps
jacktan23
I lend it to my friend who uses it with his view quest....very fast woh
I used it with Viewqwest fiber, watched many HD latest movies and variety shows without any lag and problem until I switched to STARHUB.. all the latest movies and variety shows like Running Man and 非诚勿扰 which are airing on STARHUB cable tv are blocked! :(
ng_srui
May i know where to buy it and is it in chinese interface? or able to change language?
sellwatch
how to install pp stream and funshion?
IcyJade
hi, i wanted to ship in from china taobao but xiao mi tv box upgraded version is wifi dual core and it itself like can install streaming software. seems like airplay function seldom use if for watch show. Actually i just want to let my dad watch show on tv, coz he keep use mini ipad to watch, screen too small. its like a bit redundant to have the box? but lightning cable i heard cannot full screen and china streaming sites cannot display properly? anyone can advice? thanks.
dfoong
Need help with my Xiaomi box
I just bought a xiaomi box, feel the speed is fantastic. I buy AC Ryan media player before. I feel xiaomi worth the price, and the video is very smooth, it is very easy to use. Please take note that the original set might not be sufficient, you may need to buy few additional cables. I bought two additional cable.
Bro, my xiaomi box didn't seems to work at all. It went in circle trying to download but in the end it failed. I'm on Singtel open net. Any help would be greatly appreciated!!! thanks in advance.
mingisland
Selling 5 new xiao mi 2
Hi guys,
I have 5 new ( 2nd generation ) xiao mi, do let me know if you guys interested in buying.
Cheers
