No lah. Just anyhow whack info only.
Apply it sometimes. I know laziness can be the reason but try to apply it sometimes. Sometimes better than never.
Think might need death bro's help on this. From what i know, there is no shampoo for permed hair. Shampoo for coloured hair, there is. HE shampoo will be okay but remember to use conditioner or hair care products in the beginning. Trust me, it will be quite dry. If you ignore the dryness, its going to bite back on you next time. Once you realized the dryness is more or less gone, you can try to reduce the usage of the haircare but most importantly, you should keep things consistent. And just in case your hair stylist didnt tell you (which i doubt he wont), don't shampoo your hair on the day after you permed. It will destroy the bonds i think (sorry, my science not good). So what will be the consequences if you shampoo right after perming, the perming effects will be lost very fast so you might not realize the difference shortly thereafter but perhaps 1 month down the road, you might not have the wavy and permed effects anymore.
I ought to say that shampoo-ing after perming is NO-NO from what i know. But shampoo-ing after dying is YES for me. A lot of people said no shampooing after dying but i believe it doesn't matter. So these two cases are different for me. Correct me if i am wrong. Especially pointers from death scientist bro.
